Members Demps Posted February 10, 2021 Members Report Posted February 10, 2021 Does anyone have an idea as to what causes it to become difficult to get thread thru feedhole on top of machine to the needle? Does anyone have a parts diagram for this needle/feed assembly? Quote
Members Constabulary Posted February 10, 2021 Members Report Posted February 10, 2021 Do you have a manual? Are you using a threading wire? There is a paddle spring at the end of the needle bar you only an pass with a proper threading wire. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted February 10, 2021 Moderator Report Posted February 10, 2021 You can buy the same threading wire as is used in Singer patchers. They have a finger loop on top of a thin rod that has a split cut into the bottom. The split holds the thread as you push it through, past he paddle spring, to the needle. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Demps Posted February 28, 2021 Author Members Report Posted February 28, 2021 Thank you for your response. Glad to see you can purchase these threading wires thru Amazon. Quote
