Members rlevine Posted February 19, 2021 Members Report Posted February 19, 2021 I'm rehabbing a Singer 110W125, and it has lovely paper gaskets on the gearboxes. Before I remove them, what do folks use to replace the gaskets if they're (inadvertently :p) damaged? Left to my own devices, I'll look for very thin detroiter vegetable paper, but I'm curious if there is another recommended material. Thanks! Rick Quote
CFM chuck123wapati Posted February 19, 2021 CFM Report Posted February 19, 2021 3 minutes ago, rlevine said: I'm rehabbing a Singer 110W125, and it has lovely paper gaskets on the gearboxes. Before I remove them, what do folks use to replace the gaskets if they're (inadvertently :p) damaged? Left to my own devices, I'll look for very thin detroiter vegetable paper, but I'm curious if there is another recommended material. Thanks! Rick look in mcmaster carr they sell gasket materials Quote
Members rlevine Posted February 19, 2021 Author Members Report Posted February 19, 2021 2 hours ago, chuck123wapati said: look in mcmaster carr they sell gasket materials Thanks! Discovered our local O'Reilly Auto carries 1/64" vegetable paper, too. Didn't have to pay McMaster's shipping rates! Rick Quote
CFM chuck123wapati Posted February 19, 2021 CFM Report Posted February 19, 2021 9 minutes ago, rlevine said: Thanks! Discovered our local O'Reilly Auto carries 1/64" vegetable paper, too. Didn't have to pay McMaster's shipping rates! Rick awesome ! good luck with your rebuild friend. Quote
DonInReno Posted February 20, 2021 Report Posted February 20, 2021 I have a question - is the feed dog of your machine essentially a disk that rotates in step with the needle feed? Is the main shaft connected to the lower shaft with a rubber belt or a drive shaft? Ok, two questions. Quote
Contributing Member fredk Posted February 20, 2021 Contributing Member Report Posted February 20, 2021 1 hour ago, rlevine said: Thanks! Discovered our local O'Reilly Auto carries 1/64" vegetable paper, too. Didn't have to pay McMaster's shipping rates! Rick make sure the replacement gasket is the same thickness as the original. any difference can throw tolerances out Quote
DonInReno Posted February 20, 2021 Report Posted February 20, 2021 I just ran across a few photos of a disassembled machine like yours that showed the parts I was curious about - what an interesting design! I’ve ran across a few of these and always avoided them not knowing they were needle feed - now I’m excited to pick up the next one that comes along. Quote
Members rlevine Posted February 20, 2021 Author Members Report Posted February 20, 2021 It has two lower shafts, one for the hook and a separate one for the feed. The wheel feed is driven separately from the hook by reduction gearing from bottom bevel gear housing. There's an interesting wrinkle in that the needle rock is set for the middle stitch length if the three stitch gear sets are close together, otherwise it may need to be adjusted when the stitch length is switched. Apologies for the late response, I took some pics this morning. Rick Quote
Members rlevine Posted February 20, 2021 Author Members Report Posted February 20, 2021 ,,,and the upper/lower coupling is a drive shaft, not a belt. Quote
DonInReno Posted February 20, 2021 Report Posted February 20, 2021 Thanks for the pictures! That’s an interesting arrangement. Quote
