Members hunte567 Posted March 8, 2021 Members Report Posted March 8, 2021 Im looking for ingredients for snake tanning for leather work. Im told the 50/50 alcohol-glycerin will keep the skin from being glued. I dont want to use an any kits or solutions from a taxidermy companies. I want to do this old school. Let me know you boys that have been doing this for awhile use. Thanks Quote
CFM Frodo Posted March 28, 2021 CFM Report Posted March 28, 2021 About 20 days late. You were told correct a 50/50 mixture pour into glass jar make sure the skin is 100% covered store it out of direct sunlight for 7 days when you remove it, check for and odors, if odors put it back for a another day using a stick, roll the hide onto the stick with the head first, pull the hide / stretch it as you are rolling it up then set it aside to dry Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members Agarbers Posted December 25, 2021 Members Report Posted December 25, 2021 My method is to pin the skin flesh-side up on a sheet of Styrofoam. As the skin starts to dry I start painting the 50/50 mix on. I do that a few times a day for a few days. When the flesh stops absorbing it, I stop. I sometimes even wipe off the excess and maybe daub it off with an alcohol soaked rag. I do not apply any mix to the scale side. I let the skin sit for a few weeks before using. Yes, sometimes it is hard to glue to a backer. If you're using the Tandy belt buckle kits turn the buckle blank backwards so the the flesh side of the snake is glued to the skive side of the blank. Keep in mind I live in arid Arizona so if you are trying to do this in a more humid place, you may need to adjust things. Quote
CFM chuck123wapati Posted December 25, 2021 CFM Report Posted December 25, 2021 21 minutes ago, Agarbers said: My method is to pin the skin flesh-side up on a sheet of Styrofoam. As the skin starts to dry I start painting the 50/50 mix on. I do that a few times a day for a few days. When the flesh stops absorbing it, I stop. I sometimes even wipe off the excess and maybe daub it off with an alcohol soaked rag. I do not apply any mix to the scale side. I let the skin sit for a few weeks before using. Yes, sometimes it is hard to glue to a backer. If you're using the Tandy belt buckle kits turn the buckle blank backwards so the the flesh side of the snake is glued to the skive side of the blank. Keep in mind I live in arid Arizona so if you are trying to do this in a more humid place, you may need to adjust things. i let mine dry/cure for a long while and there are no problems with glue up. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Leathershark Posted January 11 Members Report Posted January 11 I work a lot with snake skins, the glycerin method is not tanning. It only preserves the skin. True tanning turns the skin to leather. I will not buy glycerin preserved skins for leather work. Hard to glue, and they have a yellow look to them. The skins I get from my supplier are flat and almost white looking on the flesh side. He holds his formula very close. will not tell anybody how he does it. But I am in leather work not tanning business. So best to just buy the skins from him. Quote
Members Leathershark Posted January 16 Members Report Posted January 16 I just got in some tanned rattlesnake skins. that are not glycerin preserved, you can see the difference. no tack holes, they are perfectly dry, no oil feel , the flesh side is dry and almost white. They lay flat no curl. Quote
