Members bigsig11010 Posted April 9, 2021 Members Report Posted April 9, 2021 I have a Seiko stw 8/consew 225. I’ve seen videos of machines using a roller foot. Could I put a roller foot on my machine and I guess more importantly why would I want or need to? Quote
Moderator Wizcrafts Posted April 9, 2021 Moderator Report Posted April 9, 2021 I don't know of any roller foot that mounts onto a walking foot machine's presser bar. They usually bolt onto a straight stitch machine that only has one foot. You might have to replace the presser bar to do this. Then, the inside foot would have to go. This would leave you with the problem of the inline feed dog making contact on only its left side. Then you'd have an issue when the feed dog drops to move forward. The roller would push the work down into the big slot in the throat plate. I would be simpler to buy a straight stitch machine that meets your requirements, then buy a roller foot/feed dog/throat plate conversion kit. Th throat plate has a narrow slot that the roller doesn't drop into. The feed dog is also narrow, but with aggressive teeth. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted April 9, 2021 Members Report Posted April 9, 2021 (edited) EDIT: deleted - got you wrong. I would not "downgrade" a walking foot machine even if it was possible. better look for a needle feed or drop feed machine you can convert. A cheap Singer 31 / 31K comes to my mind. The 31K has the same bed size as your 225 so you can just switch the machine heads as needed (space saving) but you may need a 2nd V-Belt. Edited April 9, 2021 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members bigsig11010 Posted April 9, 2021 Author Members Report Posted April 9, 2021 Great info. Thanks. Quote
