What’s your preference on mounting breast collar dee’s and other small Dee rings?  Rawhide, pre made metal tabs, or leather?  Pro’s and con’s of each?
Hello Dirty Dusty,
I am a very amateur maker so take my thoughts with a grain or three of salt...  I was taught that the dee rings should be set up to tear out on their own in the event of a major wreck.
I always attach mine independently of any major components so that if something really gets westy they will break and not wreck something major like a rigging plate.  I usually build mine of leather laced together with kangaroo lace.
I have a saddle in for repair right now where the maker had attached the breast collar dees with tin loops riveted into the rigging plates.  The owner had a decent wreck with a colt and by the time the saddle broke free of the horse the breast collar had pulled the dees out of the rigging plates making for a fairly major repair.  The rigging plates were ripped nearly in half.
Just my 2 cents.
RDL
RDL
Makes some very good points.  Now, I wonder how to place breast collar dees.  Lately, I've been incorporating my dees in the latigo carriers.  I seldom use clip (metal) and dees because the hole in the clip doesn't always line up where I what it, and drilling into stainless steel cost more in drill bits than it's worth.  I do believe that breast collar dees should be attached to the tree and not to skirts and rigging plates.  I usually use leather to attach the dees, and rawhide if the repair (original equipment) of a saddle calls for it.  Also, for dees at rosettes for tying on stuff, I like to use rawhide.
So, what did you decide on your fenders?
1 hour ago, Goldshot Ron said:
RDL
I have one pattern made already, like the stohlman book shows. I think I will modify it some. Pondering how to work around my stirrup strap slots. I think I may have an issue with the slot under the tree being too narrow. I am gonna cut my straps and see if it looks like it will work.
I believe Stohlman's book shows 3" wide leathers, so if your slots are a little too small for 3", go down to 2 1/2".  I've worked on a lot of saddles with less than  2 1/2" wide leathers, and they have held up quit well.
