haveing problems with my leather skiver machine
getting lines along the skived area
new knife on and sharpend but lines along the cut area about 3cm apart
any advise please
any advise please
Hi There,  you will need to keep sharpening until the lines go away.
thanks for the reply
it seems sharp and i marked the knife with pen then sharpend untill all gone
i was wondering if the bush was worn
thanks for advise
What skiver do you have?
And where, exactly, are the lines showing up on the skived area?
very old fortuna
lines going across the width of the skive at regular intervals
6 hours ago, Midlandssewing said:
very old fortuna
do you have a manual??
no its to old
very old fortuna
I have a pdf of a newer fortuna which would also apply to your old one in the way of setup and sharpening? if you want, send me your email by private message at the top of the page and i can send you a copy. What kind of feed wheel do you have on at the moment?? rubber, steel or stone?
If your bush is worn then i would imagine your knife would have a lot of play/wobble?? does it have a lot of play??normally the lines will disappear when you have it sharpened well, the bevel should be continuous all the way around, and would recommend raising your stone feed wheel up to lightly touch the inside of the bell knife to take off the burrs. If it is the bush then that is obviously a case of replacing it.
Edited by jimi
midlandssewing@gmail.com
did not seem to leve lines untill i put the new knife on
had to be moved all the way back and it might just be it needs to ware away some of its self befor it can be ajusted just right
dont normaly have a problem with fitting knifes and all ways use good quality knifes
stone feed wheel looks good
debured the inside with stone
no visable wobble on the blade that i can see
just wondered if part of the bush was worn and moveing it so far back it was in a worn part
marked knife with pen and sharpend untill pen mark gose
its not my machine i fitted it at a frends for him as i fix sewing machines normaly
manuals are allway helpfull
thanks for the help
