On 5/16/2021 at 11:51 PM, Constabulary said:
Do you have a link to that video? Screw in type needle holder is the most common nowadays. Well I do not know your needle bar. Is the needle holder replaceable - probably? If yes maybe you can just replace the needle holder and you are done. But I don´t know your machine...
If not then the NB diameter also matters. The timing marks do not work when you install the NB in a foreign machine but that does not really matter.
Well, a double needle machine is a different story. I have single needle machine and used a needle bar from a Dürkopp machine which I had in my spare parts box and because it was shorter than the OEM NB I had to install a longer NB Guide. I´m not sure if you want to go that way. It may require drilling out the casting if you cannot find a NB guide with the correct length and diameter.
If I was in your position and cannot replace the needle holder then I would look for a Singer 212 needle bar. I´m not sure maybe there is a double needle bar which is longer but I don´t know so my choice would be a Singer 212 NB. Then you need a needle holder with the correct needle distance that matches your needle plate.
Needle bar:
https://www.ebay.com/itm/153445408972
For the needle holder you most likely have to buy a whole 212 gauge get with correct needle distance - not sure what your needle distance is
https://www.ebay.com/itm/142635430976
I'll look into those options when and if I get tired of these type of needles, but not feeling the motivation as I have basics like getting the table routed to take care of first. Thank you for the leads on parts as usual. I'm glad you're part of the community, you're very knowledgeable and helpful, as well as entertaining. Here's the video, skip to 13:47 for the beginning of the needle bar talk, beginning with him saying the word "presser bar" (he misspeaks here without correction, he means to kick off the "needle bar" segment). Juki LH-515 is the model he quotes as being compatible with his machine but too long. I bet it would be the same for my cylinder bed singer 153w102 since it is a needle feed too, I'd have to do some measuring between that and my 52w...
tible o
Edited by AlizabethThomas
  • Replies 22
  • Created
  • Last Reply
Top Posters In This Topic
I finally got the routing of the table done and it fits and is padded. The hinges are a lot of work as I excpected, since I wanted to fabricate my own. There'a another step to making them I didn't want to have to do but here I am. Hey, the guy I bought a set of table legs from had this Singer lamp he gave me. That's about all the logo I need, if i even keep it on there. It puts the light where the work is coming out, but I thought I'd try it. The light in the room is probably enough. Then I need to make an oil pan as well.
