Well, I finally got back to the Consew 226R-2 and it turned out to have more issues than I had suspected.  It had been set up with a Tennessee Attachments piping binder and pretty much every adjustment that could be monkeyed with had been.  I got the new needle plate, dog, foot sets etc so today I got it put together and fully adjusted .
The stitch length had been adjusted so it couldn't go lower than 9 stitches per inch in forward but would run at 4 SPI in reverse (the machine is supposedly 5 SPI max in either direction) so a search here set me straight on fixing that and getting them to match, I put in the new needle plate and dog in and adjusted the dog height, had to re-index the stitch indicator ring to match the actual stitch length, adjust the presser foot height etc.
I cut a hunk of 840D nylon packcloth and used it to do the stitch length and tension final adjustments. I kept folding it and 16 layers later....
As I had hoped it would, the machine acts like it's not even there.  Now that the machine is cleaned up it looks pretty good.  It came from a state auction out of the North Carolina prison system and it has far less wear and tear than I would have expected.
And late last month I got a Consew 227 cylinder bed machine that was correctly set up and running well.  It'll be an interesting ride learning to sew on it while standing.
Best regards to all,
Lance
Current machines: Consew 226R-1, Consew 227, Necchi BU Mira in an industrial table with an antique Atlas clutch setup.
@LanceR
Your images cannot be viewed without being a logged in member of that website that's hosting them. Upload your photos to our server if you wish to share them on LWN.
Posted IMHO, by Wiz
Thank, Wiz
When I posted the post I got a message stating that there was a size limit of 1.46 MB.  I'm a bit of a dinosaur with computers and would appreciate any advice as to what to do.  I don't remember having photo loading issues in the past although I am using a new phone.  If I'm reading things correctly the pictures are around 3 MB.
EDIT: I'm still not getting notices of replies to the thread and don't see a way to check or change that.  And is there a time limit to edits?  I don't see a way to edit the post from last night.
Lance
Edited by LanceR
There is a time limit of just an hour or two for editing a post. However, moderators can edit any time.
There are programs that manipulate photos and can save them at greatly reduced file sizes, with minimal loss of detail. I sometimes use FastStone Photo Resizer for quick reduction. I have other expensive programs that can do magic when needed, but Photo Resizer does it good enough for our purposes..
Posted IMHO, by Wiz
Thanks.  I'll look into it.
Lance
Unless you're new phone has a lot of storage  or a large Micro SSD card 3 megapixel will fill the storage space fairly quickly. From the net, =Dimensions: 600px to 650px is still the best image size for email. The most popular screen resolution worldwide—across both mobile and all platforms—is 360×640.
On my Android phone at the top left of the phone screen is a wheel. That drops down a menu and has a help place to click on. Hope this helps.
