Members regius Posted June 20, 2021 Members Report Posted June 20, 2021 just had delivered a brand new Juki LU-1508NH. The machine was assembled in the factory, mounted to a table, shipped on a pallet to my dealer's store in Hartsdale NY. He threaded it and sewed, no problem. His guy then unmounted the body from the table and delivered it, I helped re-mount the machine. Threaded the top, dropped the bobbin into the case, now, all of a sudden, the bobbin case area does not move anymore. Hand cranked the wheel, the walking foot and needle all move normally, the bobbin components just does not spin, so the needle can't pick up the bobbin thread. Any idea why? nothing sounds funny, in fact, it's so silent and sounded like something is not engaging. Quote
JJN Posted June 20, 2021 Report Posted June 20, 2021 Read the manual about the safety clutch. It sounds it is disengaged. Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
Members regius Posted June 20, 2021 Author Members Report Posted June 20, 2021 another quirk I noticed about the LU 1508 is the extra wiggle room on the reverse lever? here's a video, why??? Quote
Members regius Posted June 20, 2021 Author Members Report Posted June 20, 2021 wow, UWE channel, life saver!! https://youtu.be/N-MClgDKnq4 JJN, thank you!! I'll try not, I did notice that silver button. Quote
Members regius Posted June 20, 2021 Author Members Report Posted June 20, 2021 so, long story short, it worked. Pushed the clutch button down and hand cranked in opposite direction until I hear the click. There was a twist to the plot though, after re-engaging the clutch, i started cranking in the normal direction towards me, again. but the entire mechanism just felt so tight and sooooo much friction. as if the whole clutch trick never mattered. i was so scared, it's like i'm about to bend some metal. then it passed the "threshold" and everything started to spin normally, and I started to hear the healthy squeal noise typical of industrial machines. I noticed a detail on the 1508 manual (never noticed this on the DNU manual), it says something about do not run the machine idle when a loaded bobbin is inside the case. When I wind the bobbin, without simultaneously sewing a job, I typically lift up the foot with the rear lever, then I run the machine dry, so the needle goes up and down very fast (and so does the bobbin case), while the bobbin is being loaded. Is this good? Quote
JJN Posted June 20, 2021 Report Posted June 20, 2021 Never run your machine with a loaded bobbin while you are not actually sewing. Such as winding a bobbin. Even if the upper thread is removed, the thread will birdnest around the hook and cause the kind of jamming that will trigger your safety clutch. If you did this, this is most likely the cause of your problems. I suspect you still have thread wrapped around your bobbin case or hook. I suggest you clear any remaining thread from your hook before you sew again. Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
Moderator Wizcrafts Posted June 20, 2021 Moderator Report Posted June 20, 2021 10 hours ago, JJN said: Never run your machine with a loaded bobbin while you are not actually sewing. Such as winding a bobbin. Even if the upper thread is removed, the thread will birdnest around the hook and cause the kind of jamming that will trigger your safety clutch. If you did this, this is most likely the cause of your problems. I suspect you still have thread wrapped around your bobbin case or hook. I suggest you clear any remaining thread from your hook before you sew again. Bingo! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
