Members Ed in Tx Posted June 27, 2021 Members Report Posted June 27, 2021 Going up one needle size has helped me numerous times. I normally sew heavier leather and use A Cobra Class 4 machine but when I have had issues with fraying or stitch skipping when sewing some pieces a larger needle generally does the trick. Quote
Members Dwolf01 Posted June 27, 2021 Author Members Report Posted June 27, 2021 Thank you both for your help! I ordered through wakwak. I don’t know what I would do without leatherworker.net! Quote
Members LindanHotAir Posted June 28, 2021 Members Report Posted June 28, 2021 The titanium nitride coated needles run cooler and 5 to 10 times longer than standard finish needles. Groz-Beckert labels them GEBEDUR. Quote
Moderator Wizcrafts Posted June 28, 2021 Moderator Report Posted June 28, 2021 3 hours ago, Dwolf01 said: Thank you both for your help! I ordered through Wawak. I don’t know what I would do without leatherworker.net! Did you also order their double sided leather tape? They stock it in 4 widths, all in 60 yard lengths. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Dwolf01 Posted July 1, 2021 Author Members Report Posted July 1, 2021 Got my dp x 16 needles sizes 18, 20, 21 worked like a charm!!!! (They didn’t have 19). When I had to add another layer or two I just went up to the sz 21. Wizcraft, I will try the tape as well. So far I have been sewing without glue or tacking. As things get more complicated I will need to. Thank you for the recommendation! Seriously, I can not thank you all enough for your help and support as I am just starting off in this hobby and as you all know there is a A LOT to leant. You are all fantastic!!!!!!! Quote
