Members Jholden0 Posted July 3, 2021 Members Report Posted July 3, 2021 I recently purchased a Singer 51w-25. I want to purchase a few parts for it, but cannot find any information about it at all. I haven't even been able to find another example of one online anywhere. Can anyone tell me what parts may be interchangeable from other post bed machines? I don't really know anything about the type or model of this machine. Any information would be appreciated. Thank you, Jesse Quote
Members Constabulary Posted July 3, 2021 Members Report Posted July 3, 2021 (edited) Please post pictures of your machine. There were 2 Types of 51w machines and early and and a later model. Maybe this helps a little bit: Edited July 3, 2021 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Jholden0 Posted July 3, 2021 Author Members Report Posted July 3, 2021 I am on vacation at the moment, so I don't have any good photos at this time. I attached what I have. I want to thank your for your replies to my questions. The post about your restoration of the singer 51wSV2 machine was actually the reason I joined the forum. I was hoping someone could answer some questions that were not covered in those posts as well as offer some further explanation on the topics you covered. I have 5 sewing machines but am a novice at best. I bought the brother double needle and this machine from an auction for the Maryland department of corrections. Both of them were used to manufacture shoes and garments for inmates by inmates. Pretty interesting history I think. At least the little bit I do know. Thanks again! Quote
Moderator Wizcrafts Posted July 4, 2021 Moderator Report Posted July 4, 2021 I can tell you that this model is a light duty straight stitch machine with a fixed presser foot and bottom feed. It uses G size bobbins which are also used in the Singer 111 series machines. I have a walking foot version called the model 168. I use #69 or #92 thread in it. It is a great machine for sewing hats, ball caps, bags, etc. Basically, it sews around the tall, narrow post. If it can fit over the post you can sew it. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Jholden0 Posted July 4, 2021 Author Members Report Posted July 4, 2021 Fantastic. Thank you for the info. I actually purchased it to sew bags and shoes where my consew 226 is lacking. Especially when I comes to stitching bags. Any idea how to adjust the feed dog height? It seems that the feed dogs do not actually "grab" the work piece and feed it through the to stitch. They sit about 1-2 mm above the needle plate at their highest point won't feed. I can't really diagnose the issue. I don't know where to really start. There isn't a vibrating walking foot so it isn't a compound feed. I assume the feed dog is the only feeding mechanism? Quote
Members Constabulary Posted July 4, 2021 Members Report Posted July 4, 2021 (edited) 59 minutes ago, Jholden0 said: Any idea how to adjust the feed dog height? loosen this screw and you can raise or lower the feed dog. Removing the front plate (held by 4 screws) makes it a bit easier. 59 minutes ago, Jholden0 said: I assume the feed dog is the only feeding mechanism? Yes, that´s the only mechanism. Have you checked the stitch length adjuster? Lever up is short lever down is longer. If the lever does not move then loosen the set screw on the front side Edited July 4, 2021 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Jholden0 Posted July 4, 2021 Author Members Report Posted July 4, 2021 You are a saint. Thank you. Thank you. Thank you! I will give that a go when I return home. I also plan to attempt to refurbish this machine as much as I can. When you powder coated yours, did you remove any of the internals when you were curing it in an oven? Quote
Members kclark Posted August 11, 2024 Members Report Posted August 11, 2024 I have a singer 51w 28 i am looking for a tension assembly for this machine and so for no luck. Anyone have a place of business were i can get two of these? Quote
Members Constabulary Posted August 11, 2024 Members Report Posted August 11, 2024 15 hours ago, kclark said: I have a singer 51w 28 i am looking for a tension assembly for this machine and so for no luck. Anyone have a place of business were i can get two of these? Please post pictures of your machine then we know if it the 1st or 2nd type 51w Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
