JJN Posted July 14, 2021 Report Posted July 14, 2021 45 minutes ago, uncmph00 said: . Now you're asking me to try them out and let you know if they are too big? I think what Wiz was asking is are the U size bobbins you are getting 'in spec''. Sometimes aftermarket parts are made with slight dimensional errors and cause problems. Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
Members uncmph00 Posted July 14, 2021 Author Members Report Posted July 14, 2021 2 hours ago, JJN said: I think what Wiz was asking is are the U size bobbins you are getting 'in spec''. Sometimes aftermarket parts are made with slight dimensional errors and cause problems. Thanks. I was kind of just being silly and joking around. The look exactly the same size, but I will try one of them this week. Quote Current machines: Cobra Class 26 Compound Feed Sewing Machine Rex 26-188 Walking Foot Sewing Machine Consew DCS S4 Bottom Feed Skiving Machine Happy HCS 1201-30 12-Needle Embroidery Machine http://kevinjharrell.com
kgg Posted July 14, 2021 Report Posted July 14, 2021 8 hours ago, JJN said: Sometimes aftermarket parts are made with slight dimensional errors and cause problems. I agree particularly bobbins as they sometimes are not balanced but usually the center shaft can be either to small or to large. I have seen some bobbins so bad that when you try to wind thread on them they actually wobble on the winder so you can imagine what they are doing when inserted. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members uncmph00 Posted July 23, 2021 Author Members Report Posted July 23, 2021 On 7/14/2021 at 7:28 AM, kgg said: I have seen some bobbins so bad that when you try to wind thread on them they actually wobble on the winder so you can imagine what they are doing when inserted. These are okay. They're definitely not perfect. The center shaft is a bit small and they wobble a little. I had to do some adjusting to actually wind them on the winder. Quote Current machines: Cobra Class 26 Compound Feed Sewing Machine Rex 26-188 Walking Foot Sewing Machine Consew DCS S4 Bottom Feed Skiving Machine Happy HCS 1201-30 12-Needle Embroidery Machine http://kevinjharrell.com
