Hello.
This time, I got the Singer sewing machine 91k6.
The question is I don't know how to connect the threads.
First, I connected the thread to the lower post. (I don't know if I connected it properly.)
Then I connected the thread to the upper needle bar. (When viewed from the front, the thread came out from the back to the front.)
And when I sew, only the upper thread is sewn and the lower thread is not pulled up at all.
what kind of problem...
If anyone knows how to connect the threads, please let me know.
Edited by ddiuni
  • Replies 36
  • Created
  • Last Reply
Top Posters In This Topic
You never mentioned passing the thread through the take-up lever. That lever is what pulls up the bobbin thread.
Can you take a small resolution picture of the thread path from the post on top, on down? We can see what you missed. But, I am fairly certain you forgot to thread through the take-up lever.
Posted IMHO, by Wiz
The thread is connected to the lower bar.
I wrote down the numbers in order.
Please tell me what's wrong
Edited by ddiuni
1 hour ago, Wizcrafts said:
์‹ค์ฑ„๊ธฐ๋ฅผ ํ†ตํ•ด ์‹ค์„ ํ†ต๊ณผ์‹œํ‚ค๋Š” ๊ฒƒ์— ๋Œ€ํ•ด ์–ธ๊ธ‰ํ•œ ์ ์ด ์—†์Šต๋‹ˆ๋‹ค. ๊ทธ ๋ ˆ๋ฒ„๋Š” ๋ฐ‘์‹ค์„ ๋‹น๊ธฐ๋Š” ๊ฒƒ์ž…๋‹ˆ๋‹ค.
ํฌ์ŠคํŠธ ์œ„์—์„œ ์•„๋ž˜๋กœ ์Šค๋ ˆ๋“œ ๊ฒฝ๋กœ์˜ ์ž‘์€ ํ•ด์ƒ๋„ ์‚ฌ์ง„์„ ์ฐ์„ ์ˆ˜ ์žˆ์Šต๋‹ˆ๊นŒ? ์šฐ๋ฆฌ๋Š” ๋‹น์‹ ์ด ๋†“์นœ ๊ฒƒ์„ ๋ณผ ์ˆ˜ ์žˆ์Šต๋‹ˆ๋‹ค. ๊ทธ๋Ÿฌ๋‚˜ ๋‚˜๋Š” ๋‹น์‹ ์ด ํ…Œ์ดํฌ์—… ๋ ˆ๋ฒ„๋ฅผ ํ†ต๊ณผํ•˜๋Š” ๊ฒƒ์„ ์žŠ์—ˆ๋‹ค๊ณ  ํ™•์‹ ํ•ฉ๋‹ˆ๋‹ค.
๋‹ค์‹œ ์ˆœ์„œ๋Œ€๋กœ ๋†“์Šต๋‹ˆ๋‹ค. ๋ฌด์Šจ ์ผ์ธ์ง€ ์•Œ๋ ค์ฃผ์„ธ์š”
That is I think the first problem. The thread in the video that you have asked questions on before shows that at 40 seconds in that the thread comes from the front and goes to the back. In picture 11 above the long slot of the needle is facing the front as it should and and therefore that is the way the thread should follow down for it to be able to form a loop in the scarf on the back side of the needle. In picture 12 it shows the thread is coming as you said from the back which is wrong. XXXXXX
ย
YouTube Channel
Instagram
1์‹œ๊ฐ„ ์ „ RockyAussie๋Š” ๋‹ค์Œ๊ณผ ๊ฐ™์ด ๋งํ–ˆ์Šต๋‹ˆ๋‹ค.
๋‹จ์„œ๋ผ๊ณ  ์ƒ๊ฐํ•ฉ๋‹ˆ๋‹ค. ์ด์ „์— ์งˆ๋ฌธ์ด ์‹œ์ƒคํ•˜๋Š” ๋ฐ”๊ฐ€. 11์—์„œ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ๋„˜๊ฒŒ ๋‹ฌ๋ ค ๊ฐ€๊ฒŒ๋˜๋Š” 11 ๋ฒˆ ์งธ ๊ถ์—์„œ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ๋„˜์–ด๊ฐ€๋Š” ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œ์ฉ ํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œ ํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œํ›Œ. ๊ทธ๋ฆผ 12์—์„œ ๋‹น์‹ ์ด ๋ณด๊ณ  ์žˆ๋‹ค๋Š” ์‚ฌ์‹ค์„ ์•Œ๋ ค์ค๋‹ˆ๋‹ค. ๊ฒƒ์ž…๋‹ˆ๋‹ค. XXXXXX
ย
Number 17 is the scarf at the back.
You say to connect the thread like number 17 in the photo.
But even if I connect it like No. 17 and lower the presser foot and sew it, it is not sewing at all.
I do not know this machine myself. This video that you may not have seen does look to be a similar type and in the comments section below it they have answered someone as to what needle type they use. You may be able to contact them.
If you could take some pictures showing the thread path in the top of the machine may help. It may also be out of timing and normally you can see this by Watching where the scarf of the needle is when the hook is passing the needle. The eye of the needle should be 1 to 2mm below where the hook is passing the needle. If this is not the case then the hook has to be adjusted around. The hook in your pictures does look very worn down.
YouTube Channel
Instagram
7 hours ago, RockyAussie said:
์ด ๊ธฐ๊ณ„๋Š” ์ €๋„ ๋ชจ๋ฆ…๋‹ˆ๋‹ค. ๋‹น์‹ ์ด ๋ณด์ง€ ๋ชปํ–ˆ์„ ์ˆ˜๋„ ์žˆ๋Š” ์ด ๋น„๋””์˜ค๋Š” ๋น„์Šทํ•œ ์œ ํ˜•์œผ๋กœ ๋ณด์ด๋ฉฐ ๊ทธ ์•„๋ž˜์˜ ๋Œ“๊ธ€ ์„น์…˜์—์„œ ๊ทธ๋“ค์ด ์‚ฌ์šฉํ•˜๋Š” ๋ฐ”๋Š˜ ์œ ํ˜•์— ๋Œ€ํ•ด ๋ˆ„๊ตฐ๊ฐ€์—๊ฒŒ ๋‹ต๋ณ€ํ–ˆ์Šต๋‹ˆ๋‹ค. ๊ทธ๋“ค์—๊ฒŒ ์—ฐ๋ฝํ•  ์ˆ˜๋„ ์žˆ์Šต๋‹ˆ๋‹ค.
๊ธฐ๊ณ„ ์ƒ๋‹จ์˜ ์‹ค ๊ฒฝ๋กœ๋ฅผ ๋ณด์—ฌ์ฃผ๋Š” ์‚ฌ์ง„์„ ์ฐ์„ ์ˆ˜ ์žˆ๋‹ค๋ฉด ๋„์›€์ด ๋  ๊ฒƒ์ž…๋‹ˆ๋‹ค. ๋˜ํ•œ ํƒ€์ด๋ฐ์ด ๋งž์ง€ ์•Š์„ ์ˆ˜๋„ ์žˆ์œผ๋ฉฐ ์ผ๋ฐ˜์ ์œผ๋กœ ํ›„ํฌ๊ฐ€ ๋ฐ”๋Š˜์„ ํ†ต๊ณผํ•  ๋•Œ ๋ฐ”๋Š˜์˜ ์Šค์นดํ”„๊ฐ€ ์žˆ๋Š” ์œ„์น˜๋ฅผ ๋ณด๋ฉด ์•Œ ์ˆ˜ ์žˆ์Šต๋‹ˆ๋‹ค. ๋ฐ”๋Š˜์˜ ๋ˆˆ์€ ๋ฐ”๋Š˜์ด ๋ฐ”๋Š˜์„ ํ†ต๊ณผํ•˜๋Š” ์œ„์น˜๋ณด๋‹ค 1~2mm ์•„๋ž˜์— ์žˆ์–ด์•ผ ํ•ฉ๋‹ˆ๋‹ค. ๊ทธ๋ ‡์ง€ ์•Š์€ ๊ฒฝ์šฐ ํ›„ํฌ๋ฅผ ์กฐ์ •ํ•ด์•ผ ํ•ฉ๋‹ˆ๋‹ค. ์‚ฌ์ง„์˜ ํ›„ํฌ๊ฐ€ ๋งŽ์ด ๋‹ณ์•„ ๋ณด์ž…๋‹ˆ๋‹ค.
I haven't sewn it yet.
A little later....
Let's test by adjusting the height of the needle bar slightly, or by adjusting the height of the needle slightly.
There is no manual, and I have no idea why sewing is not working. This is a special glove sewing machine. Even if you look at the YouTube video, the video is blurry and you can't tell because it doesn't come out properly.
