16 minutes ago, RockyAussie said:
이것은 비디오 .Groz-Beckert의 코멘트 사본입니다...........Nm 100/16, 251 EL, 251 LG, 29 BNl, 29 CB, LW x 5 T.
이 링크가 도움이 될 수 있습니다 - https://www.thethreadexchange.com/miva/merchant.mvc?Screen=CTGY&Category_Code=NDL-251
Is the needle you mentioned a 46*1 replacement needle?
  • Replies 36
  • Created
  • Last Reply
Top Posters In This Topic
I can not be certain of that I am sorry.
If you want to measure the diameter of the needle and the length from the end to the eye and maybe do a close up picture of both sides of the needle you may find another alternative. Sometimes if the diameter is the right size you can shorten them a bit to suit. This chart should give you some ideas
Edited by RockyAussie
YouTube Channel
Instagram
18분 전 RockyAussie가 말했습니다.
열심히 합니다.
우리의 길을 따라가는 길 때로는 직경이 올바른 크기 인 경우에 맞게 약간 줄일 수 있습니다 . 여러 가지 작업을 해야 합니다.
Features of 46x1 needles:
#One. Diameter 1.1mm
#2. Total length: 42.2mm
#3.The length of the groove: about 24.5mm
#4. Length of needle eye and shark: about 13.8mm
#5. Length from the tip of the needle to the eye of the needle: about 35.7mm
The result of checking the shape of the needle groove is as follows.
The shape of the needle groove for inserting the needle is as follows.
So the right screw secures the needle.
And the diameter of the needle groove is measured to be possible up to about 1.9 mm.
However, if it is this thick, the tip of the needle can touch it when it passes the hook, so it is judged that the diameter should be smaller.
Edited by ddiuni
I am not understanding this variation. Will a needle with a shank diameter of 1.75 like the needle in the chart above shown as 175x1 fit up into the needle bar or not? Sanding down  from 37.1mm to 35.7 mm would not be very hard to do. I did ask if you could post a picture of both sides of one of these needles and with a ruler along side would be better if the picture can clear enough to see well.
This is what comes up when I google 46x1 needles  https://www.thethreadexchange.com/miva/merchant.mvc?Screen=CTGY&Category_Code=NDL-46x1
YouTube Channel
Instagram
YouTube Channel
Instagram
On 2021. 11. 19. at 오후 6시 26분, RockyAussie said:
Yes, thank you for your kind notice.
Thank you for looking into this information for someone else.
I know this site through a lot of searches.
First of all, the needle I got
Only got 70/10, 80/12, 90/14. In just one month, 65/9 and 75/11 were sold out.
Referring to the table you provided, I think I will need to find a replacement.
Edited by ddiuni
