Members Piko Posted December 6, 2021 Members Report Posted December 6, 2021 (edited) I am new at this. I started about 2 months ago just for fun and I use a laser to cut my leather because I live in an apartment and work at night so I can’t hammer the holes etc. I cut the design and holes with my laser. I came up with a couple of wallet designs that i like and use all the time. I have been thinking of selling them but, today I realized that I can’t seem to find consistent leather online. In the beginning I bought from Amazon and really liked one specific seller but I can’t keep buying from them if I plan on selling things: it’s just not sustainable. So I bought a hide from Tandy. A side that is. I removed what I thought it was the belly and used pretty much the rest as, my understanding is that aside from belly and cheek/neck, the rest of the hide is good for wallets. I guess I am using the bend And the shoulder. Anyhow, the leather seems to have splotches on it. I didn't realize it until after finishing the product and applied neatsfoot oil that the blemishes became very apparent. I also think I might have not cut out all the belly and perhaps used some in my wallets because the quality looked really low. Am I supposed to clean the hide before making my wallets?if so, How do I clean it? Do I have to sand the blemishes with sandpaper? What do you guys do? I also bought panels from Weaver leather and, although I dont see the blemishes, these are orangier than the ones I bought on Amazon and Tandy. How do you guys deal with consistency when ordering? Thank you. btw, these are the wallets I am making. Nvm the pictures are apparently over the size limit. Edited December 6, 2021 by Piko Picture Quote
Members TomE Posted December 6, 2021 Members Report Posted December 6, 2021 Nice work! Inconsistent absorption of dye or oil can be caused by an inferior tanning process or surface contaminants. The cure for the former is to buy more costly leather that typically has a tighter and uniform fiber structure. My favorite is Hermann Oak. If you can visit your supplier then you can feel the substance of the leather and get a feel of the inconsistancies. Many imported hides are bleached and dry (sometimes with splotches) so they don't take up water, oil, dye consistently. Springfield Leather Co has a Youtube video on selecting veg tan leather that addresses this. For surface contamination, you can try removing with Fiebing's Deglazer. Al Stohlman mentions using oxalic acid to clean skin oil and dirt before applying a finish after letting it dry completely. 1 teaspoon oxalic acid per quart of water. I haven't tried it. Quote
Members Piko Posted December 6, 2021 Author Members Report Posted December 6, 2021 3 hours ago, TomE said: Nice work! Inconsistent absorption of dye or oil can be caused by an inferior tanning process or surface contaminants. The cure for the former is to buy more costly leather that typically has a tighter and uniform fiber structure. My favorite is Hermann Oak. If you can visit your supplier then you can feel the substance of the leather and get a feel of the inconsistancies. Many imported hides are bleached and dry (sometimes with splotches) so they don't take up water, oil, dye consistently. Springfield Leather Co has a Youtube video on selecting veg tan leather that addresses this. For surface contamination, you can try removing with Fiebing's Deglazer. Al Stohlman mentions using oxalic acid to clean skin oil and dirt before applying a finish after letting it dry completely. 1 teaspoon oxalic acid per quart of water. I haven't tried it. Thank you for your answer. I heard Hermann Oak was good: I’ll try it next. Do you buy panels (and if so, how do you know from where are they cut -ie belly, shoulder etc)? Or do you buy whole hides? I dont have much room so the whole hide/side is a pain to cut. if you don’t see any blemishes on the piece you are gonna use, you don’t clean it, right? I wonder if my issue was both the low quality hide and probably I used part of the belly. I look at pictures that mark different areas of the hide but it’s hard to say where one ends and the other one starts ( bend ends/belly starts). I’ll look into the oxalic acid Thank you Quote
Members TomE Posted December 6, 2021 Members Report Posted December 6, 2021 I buy half hides of Hermann Oak tooling leather and bridle leather from Springfield Leather. I've never been disappointed with the quality. The different grades of HO veg tan refer to how many blemishes are in the leather, the tanning is all high quality, but you have to work around more defects in the lower grade leather. You can specify which piece of the cow you want. The Springfield Leather PDF catalog has a fairly lengthy description of how to select leather for your projects, and you can call them with questions. I don't routinely clean my leather, but I use Deglazer to remove any excess Barge cement when I'm assembling prior to sewing. I do have some import hides that are difficult to cut and skive, and don't take dye evenly. Quote
Members Piko Posted December 6, 2021 Author Members Report Posted December 6, 2021 6 minutes ago, TomE said: I buy half hides of Hermann Oak tooling leather and bridle leather from Springfield Leather. I've never been disappointed with the quality. The different grades of HO veg tan refer to how many blemishes are in the leather, the tanning is all high quality, but you have to work around more defects in the lower grade leather. You can specify which piece of the cow you want. The Springfield Leather PDF catalog has a fairly lengthy description of how to select leather for your projects, and you can call them with questions. I don't routinely clean my leather, but I use Deglazer to remove any excess Barge cement when I'm assembling prior to sewing. I do have some import hides that are difficult to cut and skive, and don't take dye evenly. I’ll check Springfield leather. The Deglazer to clean before stitching! That is a great tip! Thank you! Do you use it to clean the sides or even the front of the leather? I notice that the leather gets a bit dirty when I stitch but don’t know if it is the wax from the thread or the glue. I use 1882 water based glue but the deglazer should work if it works for barge. Hopefully it cleans the wax off the leather too. Thank you again. ps, I did notice that the Weaver leather I got it is way easier to skive than the leather I get on Amazon or Tandy. Maybe better quality leather is just easier to skive. I am waiting for some pueblo from mountain rock leather so I can compare it. Quote
Members TomE Posted December 6, 2021 Members Report Posted December 6, 2021 Deglazer is fine for the grain or flesh side, even recently dyed leather. It will remove some of the waxy finish from bridle leather so I use it sparingly (can instead remove dried cement from waxy surfaces with a plastic or crepe eraser). I finish my tack with Fiebings Aussie conditioner which contains wax and fixes any dull spots caused by Deglazer. Yes, good quality leather is way easier to skive. I think it corresponds to a higher fat content in the tanning process. Moistening the flesh side can help when skiving low quality leather. Quote
Members Piko Posted December 6, 2021 Author Members Report Posted December 6, 2021 22 minutes ago, TomE said: Deglazer is fine for the grain or flesh side, even recently dyed leather. It will remove some of the waxy finish from bridle leather so I use it sparingly (can instead remove dried cement from waxy surfaces with a plastic or crepe eraser). I finish my tack with Fiebings Aussie conditioner which contains wax and fixes any dull spots caused by Deglazer. Yes, good quality leather is way easier to skive. I think it corresponds to a higher fat content in the tanning process. Moistening the flesh side can help when skiving low quality leather. Thank you so much for your help. I appreciate it. Quote
CFM Hardrada Posted December 6, 2021 CFM Report Posted December 6, 2021 (edited) The first step in achieving consistency is to stop buying leather from Tandy. Next would be to buy better, nicer leather that is already finished, even split to your specifications. Whilst I don't work for them or get kickbacks, I do recommend looking at Rocky Mountain Leather Supply. For my small goods I buy the leather from them already split (splitting is "free"**). This is the latest wallet I produced: Do note that even with fine leather "consistency" (as in "it will ALWAYS look the same [in terms of shade, grain, lustre, &c.]") will just not happen. See the last photo: the thinner leather for the inner parts, split to 1 oz is a wee bit darker and shinier than the leather for the cover, which was split to 2.5 oz, even though they're the same Sully Chevre from Alran. No two animals will have the same skin and there are variables in the tanning process that will introduce small variations in final looks. This is NOT a flaw to desperately try to avoid, unless you definitely want the uniform look of mass produced goods. These variations, "inconsistencies" if you will, are the unique signature of hand-crafted, artisanal goods, and what gives them higher appeal than those coming from a factory. ______________ ** I put "free" in quotation marks because, technically, when you buy leather and have it split to a given weight, the splitter must give you back both the leather and the split (a.k.a. suede), but RML keeps the split. Again, technically, they're not cheating you, since it costs to operate the splitting machine and they're not charging you extra for the splitting, as others would do. Edited December 6, 2021 by Hardrada Quote
Members Tugadude Posted December 6, 2021 Members Report Posted December 6, 2021 I would say the only way to guarantee consistency in leather products is to use an opaque finish. In effect, you are putting a pigmented coating over the whole surface. Nearly all of the high-end, popular purses on the market are done that way. Plus, they order in humongous batches. Buying leather and dying it yourself is going to be inconsistent. You may get lucky and/or have developed the ability to control the inconsistencies somewhat, but they'll still be there. Leather is a natural product to begin with and then you have the types of tanning and finishing into the mix and there's just a lot of moving parts. The best way to prevent variation on a specific item is to make it out of one piece of leather. Even then there can be variation, but it's your best hedge against it. Many companies include a disclaimer in their advertising which explains the issue. That way when the wallet you receive doesn't look exactly like the one you saw on your computer screen you know why. Quote
Members Piko Posted December 6, 2021 Author Members Report Posted December 6, 2021 42 minutes ago, Tugadude said: I would say the only way to guarantee consistency in leather products is to use an opaque finish. In effect, you are putting a pigmented coating over the whole surface. Nearly all of the high-end, popular purses on the market are done that way. Plus, they order in humongous batches. Buying leather and dying it yourself is going to be inconsistent. You may get lucky and/or have developed the ability to control the inconsistencies somewhat, but they'll still be there. Leather is a natural product to begin with and then you have the types of tanning and finishing into the mix and there's just a lot of moving parts. The best way to prevent variation on a specific item is to make it out of one piece of leather. Even then there can be variation, but it's your best hedge against it. Many companies include a disclaimer in their advertising which explains the issue. That way when the wallet you receive doesn't look exactly like the one you saw on your computer screen you know why. That makes sense. For now I keep the leather undyed. I just apply Neatsfoot oil to it. The black color I achieve by using vinegar in which I dissolved steel wool and then neutralized its acid with sodium bicarbonate. It’s called mordente ferroso in italian and here, probably, ferrous acetate? Thank you for your tips. Quote
