Members AzShooter Posted December 26, 2021 Author Members Report Posted December 26, 2021 46 minutes ago, chuck123wapati said: good luck I also use an old wine cork on the back side to push my awl against, it saves fingers and gives the leather some back pressure so it doesn't move. Thanks I'll try that. 45 minutes ago, fredk said: Here's an idea, I used this method 1. cut the pieces over wide, on each side which is to be sewn 2. on the inside, draw a line for the actual width, where the excess will be cut off 3. cut just outside of the actual size line and bevel the edge, trimming back to the actual size line 4. mark your stitch spacing on the bevel 5. use a round scratch awl to poke holes at your stitching points, in the centre of the bevel but angle the scratch awl so that it is at a right angle to the bevel surface It should come out on the grain side/outside of the piece about 2mm (= half the thickness of your leather) further in, or further in if you desire 6. After doing #3 on the next piece I put it up against the other piece to mark the stitch spacing, to get them the same. I use a pen to mark the two edges to go together, eg, A & A, B & B etc. I mark this on the bevelled surface so its hidden when all is glued up 7. When I glue up the edges I slide a straightened paper clip into and through a couple of sets of holes to keep it all aligned 8. with the holes premade I use a curved sewing awl to open up the holes and curved saddlers harness needles for the sewing FredK Good information. I've printed out your instructions and will give it a try. Quote
Members Klara Posted December 26, 2021 Members Report Posted December 26, 2021 I have found that Al Stohlman's instructions work - as long as I follow them. Trouble starts when I try to improve on them or cut corners. So in your place I would re-read the book, if necessary previous books as well and then do exactly as Stohlman says. Quote
Members AzShooter Posted December 26, 2021 Author Members Report Posted December 26, 2021 Klara: Thanks for that advice. I had to order one of the previous books and I'm hoping it will be here next week. Following his lessons will help. I did manage to make a small 2 X 2 box today for practice. Still have a long way to go but now I understand it a bit more. At least I didn't have any trouble with my English Edger. Got the angle right. I figure a few more practice boxes before I make one for my briefcase project. Quote
Members Klara Posted December 27, 2021 Members Report Posted December 27, 2021 Best of luck! And yes, it's always a good idea to practice with small items before starting a big project and making big mistakes... I'm off to correct a major, idiotic and unnecessary mistake that can only be explained by too much alkohol over Christmas... Quote
