If you know how to set it up, go for it! But for me personally I am exploring the option of using a lawnmower PMDC connected through a speed controller. PMDC allows to reverse the rotation to CCW that the Chinese patcher needs (most other motors are CW), and the controller allows to slow it down to a crawl by way of a tiny pulley. My patcher is on a portable base, so I cannot afford the weight of a full-blown servo motor, which you may very well consider.
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Some servo motors do have a reverse rotation switch on the back side. I have a Rex 550 watt servo with this reverse rotation direction switch while my other servo's don't have that feature.
kgg
True, but most of them are too heavy for a portable setup, in my particular case. Also, sewing machine servo motors are already CCW.
Edited by DrmCa
