I am repairing an Econosew long arm, and the stitch dial will slowly turn to the left when I sew (meaning the stitch length will gradually get longer).  I have taken off the dial and nothing seems wrong.  I have taken off the top access plate and back access plate, checked the set screws and bolts and all are tight.  The fabric thickness has not changed.  I cannot identify why the dial turns as I sew.  Has anybody had this experience or know why it could be happening?
Show the picture of the notches on the back of the dial and the spring-loaded plunger behind it that keeps it from rotation.
I had the same problem until I realized that the tapered end of the plunger was worn/rounded and I turned it sharper on a lathe.
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Not familiar with your exact machine, but it looks (superficially) similar to the same area on a Consew 206RB4 , which had a similar problem that was significant enough for them to add a thumb-button on the RB5, which now has to be pushed in to change the stitch length. Many of these *clone* machines are nearly direct copies of older designs, so someone who has an RB4 may have a come up with a workaround, if yours IS based on the consew.
-DC
Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562,  Mitsubishi LS2-180,  Seiko SK-6, Juki LG-158-1
Thanks for your answer.  I will check the end of the plunger.  There is no spring on the back of this dial and nothing pressing against it to cause pressure.
-DC
Thanks for the response.  This dial did hold correctly in the recent past, so something has change so cause it to slip.  You're right, it does look just like a Consew dial.  The Econosew is probably a clone of a Consew.
It is not on the back of the dial. It should be under the plunger, inside the casting, over the thinner step of the plunger.
