Hey everyone
I'm currently following Bob Park's method on edge burnishing, though I sometimes torture myself with doing the sandpaper method (100 grit all the way to 2000 grit) to get an amazing edge on belts.
I recently came across this video, and the tool being used at 2:07 and 3:42 and 4:12 is something I've never seen before. He appears to use it before stitching and after stitching; before the edges are painted or sanded, as well as after painting the edge. I would assume the tool is heated up.
I'm looking for way to do edges like this, assumably with a wax of some sort, as sandpaper and Bob Park's method don't work too well for thinner leathers like those seen in the video.
Can anyone shed some light on this, or a similar way to do edges like this with wax? Information on what wax and/or tools to use would also be appreciated!
  • Replies 171
  • Created
  • Last Reply
Top Posters In This Topic
If you mean this tool, it's a heat or soldering iron with a flat tip.
They come in electric or butane.
http://www.amazon.com/Power-Probe-PPSK-Self-Igniting-Soldering/dp/B001DIE9BO/ref=sr_1_54?ie=UTF8&qid=1332507879&sr=8-54
post-19342-001391200 1332507691_thumb.jp
Edited by Tree Reaper
  On 3/23/2012 at 2:50 PM, ouchmyfinger said:
Where can I see this video?
I turned the words "this video" in my original post into a link. Easy to miss though, but it's here: http://www.facebook.com/video/video.php?v=10150131553076948
http://www.amazon.co...2507879&sr=8-54
Thanks! Looks pretty similar. I assume he first uses it to minimize the slightly visible gap between multiple layers of leather, and then maybe runs it on a lower setting to melt the paint/wax into the edges of the leather. I'll have to look into it...
The "iron" is definitely a standard in the accessories industry over in Europe, I have also seen it used at Hermes and other high-end makers.
You could accomplish the same thing with irons, usually heated on an alcohol burner or even a candle (I'm old). The coloring is usually "Yankee Wax" made by Renia. It has a lot of Carnauba wax in it I suspect as the only way to put it on is to heat the iron, maybe a daub of beeswax to finish?
Art
Art
I figured it was something similar. I used a burner and an edge iron for shoemaking, but as a first-timer, I had difficulty getting it to the right temperature (ended up either not hot enough, or too hot). Thanks for the info on the wax, I'll try and find some of that asap!
  On 3/23/2012 at 10:14 PM, Andrew Chee said:
I posted a similar thread on this topic and was able to find out a little bit more information. Take a look at:
http://www.bimac.inf...ex_Page3097.htm
And
http://www.bimac.inf...dex_Page793.htm
Andrew
Awesome! Thanks so much for posting this. It looks like they're only a few kilos in weight, so I'll have to go ahead and order one. Never would have found this without you!
That looks like some type of wood burning tool/pen. FYI, burning a design into wood is called pyrography.
Here's one link, http://www.woodburning.com
When I was growing up "wood burning art" kits were a big deal along with "paint by number" kits. ;-)
Cheers!
FYI, I looked into the pricing for the Bimac burners and they are crazy expensive ($500-800). I called Campbell-Randall and they will be able to come up with something similar for a lot less money. I'm planning on giving their tools a try. Will see how it works.
Andrew
Andrew
thanks for following up! I emailed them as well and received similar pricing. I was about to commit, but it seems like you might have found something similar that wouldn't require overseas shipping...? Please send me a PM and/or keep me updated on this.
It appears there's a tip used for the bimac machines to mark edges (I would find this useful on softer and glossier leathers), so I hope the Campbell-Randal contraption would be similar in that regard, though it isn't a huge deal...
Edited by conceptdiba
PM Sent.
Andrew
  • 2 weeks later...
Hi Lippy,
That link gives me "server not found".
Art
  On 4/9/2012 at 6:08 PM, Lippy said:
After sending Peter Nitz an email, he sent me this link to the tool. http://mando.fr/index.php?dispatch=categories.view&category_id=184
The website is in French, but he said they can deal with emails in English.
Cheers!
After sending Peter Nitz an email, he sent me this link to the tool. http://mando.fr/inde...category_id=184
Cheers!
Nice!! This site is very hard to navigate... thankfully in Canada, there's always someone around who speaks french, so I'll see if I can figure out which machine/attachments I need. Thanks for posting
I have the firewall from hell on this machine, I'll try when I get home.
Art
The Mando website is a bit goofy. It may take some time to load. Also, you might try a different browser or www.mando.fr
The tools are in a section called "fileteuse manuelle" According to Peter Nitz the French call an edge crease a "filet" hence the term "fileteuse".
To me, the "power supply" appears to be the same type used in pyrography/wood burning in Europe. It looks like Mando either makes or has made the special tips for leather. The trick would be converting the power supply to work on 110 ac for those of us in the USA.
Cheers!
Cheers!
I've already attempted to email Mando about ordering. I am definitely needing clarification on the attachments/tips. Seems like there's even one specifically for using with croc, based on the description. Very confusing.
Do you think a simple adapter would suffice, regarding the power supply concerns? I believe the specific adapter would be a 220 to 110 step-down adapter...
In the US, you would need a 110 to 220 step up adapter, or straight from a single leg of 3 phase, or across 2 legs of single phase 220-240. Need to look at the schematic for the box to be sure.
Art
Art
Thanks for the info, Art. Most of this stuff goes right over my head! I received a catalogue in English from them, and here's the info on the power unit: The double-apparatus unit (like the one shown in the video) has the following info listed: 230 V – 240 V 50/60 Hz 190 W.
Does that help narrow it down for you? Thanks for your help with this. I wouldn't know where to start otherwise!
Then a standard voltage doubler would do the trick. Just watch the power rating is enough, some of them are meant for little motors and the like, but 190W isn't a lot however, I would double that at least. You can make one pretty easily and the parts are available at most electronic shops.
Art
Attached is a brochure PDF that was sent to me by www.mando.fr in response to my email about the "tool".
It looks like the Mando tips and handles would work on these products made by Janik in the UK.
http://www.patrickfaleur.com/pyrography/wpage4.htm
http://www.patrickfaleur.com/pyrography/wpage5.htm
http://www.craft-supplies.co.uk/Pyrography/Pyrography-Machines--Accs/list.htm
Cheers.
Fine leather goods.pdfFetching info...
Don't know for sure, no spec on thread size. The Mando unit is 0-20V output the Janik unit is 0-12V.
Thanks for the pdf,
Art
Cheers.
