MADMAX22 Report post Posted October 6, 2009 OK so I know you can either get left or right hand twist thread. I assume that with machines there is a reason for choosing either direction but I have no clue as I dont have one. Now for hand stitching using the saddle stitch with two needles which is the only way I stitch is there a reason for choosing either left or right twist thread. Im guess its probably a pretty easy explanation but I cant seem to figure out how it would matter. Thanks for the input. Quote Share this post Link to post Share on other sites
jimsaddler Report post Posted October 6, 2009 OK so I know you can either get left or right hand twist thread. I assume that with machines there is a reason for choosing either direction but I have no clue as I dont have one. Now for hand stitching using the saddle stitch with two needles which is the only way I stitch is there a reason for choosing either left or right twist thread. Im guess its probably a pretty easy explanation but I cant seem to figure out how it would matter. Thanks for the input. Hi Simply put. Right Handed Sewers should use Right Hand S Twist and the thread will maintain it's twist as you sew.. If you use Z Left twist it will unravel as you sew. If you're a Lefty use the Z. Have a try and you'll see what happens. Kindest Regards. Jim Saddler. Quote Share this post Link to post Share on other sites
MADMAX22 Report post Posted October 8, 2009 Thanks Jim, guess Ill stick with the right hand twist then since Im right handed. Quote Share this post Link to post Share on other sites
Rawhide Report post Posted October 8, 2009 I'm right handed and use the Left twist, and I have never had a problem with it unravelling. Left-twist thread is always used in the sewing machine because the action of the stitch-forming mechanism tends to ravel or break right-twist thread. Left- or right-twist thread may be used for hand sewing. I bought left twist in the event I ever wanted to sew with it. Quote Share this post Link to post Share on other sites
jimsaddler Report post Posted October 8, 2009 I'm right handed and use the Left twist, and I have never had a problem with it unravelling. Left-twist thread is always used in the sewing machine because the action of the stitch-forming mechanism tends to ravel or break right-twist thread. Left- or right-twist thread may be used for hand sewing. I bought left twist in the event I ever wanted to sew with it. Hi Rawhide Please have a close look at your stitch. You'll find that there is a definite tendency to unravel as you stitch with left Hand (Z) for the same reason as Machine sewing. S will lay down better for a Right Hander. Or you can use Braid which doesn't seem have the problem so much. Kindest Regards. Jim Saddler. Quote Share this post Link to post Share on other sites
Rawhide Report post Posted October 8, 2009 (edited) Hi Rawhide Please have a close look at your stitch. You'll find that there is a definite tendency to unravel as you stitch with left Hand (Z) for the same reason as Machine sewing. S will lay down better for a Right Hander. Or you can use Braid which doesn't seem have the problem so much. Kindest Regards. Jim Saddler. Hmm, I still don't see an unravel. Maybe it's because I stitch with my left needle first, then the right, and I stitch toward me... here's an example... Edited October 8, 2009 by Rawhide Quote Share this post Link to post Share on other sites
katsass Report post Posted October 8, 2009 OK so I know you can either get left or right hand twist thread. I assume that with machines there is a reason for choosing either direction but I have no clue as I dont have one. Now for hand stitching using the saddle stitch with two needles which is the only way I stitch is there a reason for choosing either left or right twist thread. Im guess its probably a pretty easy explanation but I cant seem to figure out how it would matter. Thanks for the input. Maxx, I have never seen a difference when hand stitching (saddle stitch) with any thread. I've been stitching my work for over 40 yrs. and have never had a problem with that. I prefer waxed linnen and try to never have to use more than a single strand of thread on any project. Enclosed are two examples...the holster is a few months old ...the knife sheath is over 20 yrs. old. Mike Quote Share this post Link to post Share on other sites
MADMAX22 Report post Posted October 8, 2009 Thanks for the input guys. I like handstitching now that I have become more comfortable with it and it suits my needs for what I make. I just never found much info on the differences or why. Everything shared is very helpful. Marlon I stitch starting with the right needle first and come towards me, with the face of the project to the right so I am allways going thru the front of it first. The main reason I asked was Im looking at getting some plain linen thread and wanna try my own wax/rosin mix on it. I really liked the way the waxed linen thread lays and want to experiment further. That knife sheath looks like it is holding up very well Kat. NIcely done. Quote Share this post Link to post Share on other sites
CampbellRandall Report post Posted October 9, 2009 The thread twist is more important for machine sewing than hand sewing. The sewing action by hand is about as simple as you can get, so unless you are doing summersaults while you sew, you shouldn't see much difference between the two types. Traditional sewing machines (single needle or straight needle and awl) all use left twist thread, as the mechanism is designed to work without the thread unraveling. If you sew with right twist thread in a traditional straight needle machine, it will unravel. The bobbin doesn't mater since the mechanism doesn't have far to travel. A curved needle machine, as used in a shoe shop, uses right twist. If anybody has taken a close look at these machines, although it is a needle and awl, the mechanism is upside down (needle on top, awl on bottom). So if the machine works in reverse, it make sense that it would take the opposite twist. Quote Share this post Link to post Share on other sites
oldtimer Report post Posted October 9, 2009 Hi Rawhide Please have a close look at your stitch. You'll find that there is a definite tendency to unravel as you stitch with left Hand (Z) for the same reason as Machine sewing. S will lay down better for a Right Hander. Or you can use Braid which doesn't seem have the problem so much. Kindest Regards. Jim Saddler. I use the same thread in my machines as when handsewing, and I have never seen any sign of unraveling. I use Barbours bonded nylon plus a sticky wax - no problem. I think the problem might occur when using linen thread which is poorly waxed, but I have never been up to it - so far. Quote Share this post Link to post Share on other sites
jimsaddler Report post Posted October 13, 2009 I use the same thread in my machines as when handsewing, and I have never seen any sign of unraveling. I use Barbours bonded nylon plus a sticky wax - no problem. I think the problem might occur when using linen thread which is poorly waxed, but I have never been up to it - so far. Hi Oldtimer If you look at the Knife Sheaf in the photo you'll see that the Thread has a straighter lay than when it is on the Spool. This is what I mean by unraveling. The Holster thread is hard to pick up with my eyesight. As explained in the post by CampbellRandell. There is the same tendency in Hand Sewing although most wont spot it. The lay actually becomes straighter as you sew. Please have an experiment with both twists S & Z and you'll see what I mean. I now am using a .8mm or 1.mm Polly Braid for some Sewing which doesn't seem to have any problem, except I have to use bigger needles than for wax ends. I've got some Italian Siliconised / waxed thread that is looking very good as it is rounder in profile so looks finer. I hope this is not confusing and maybe some help. Kindest Regards. Jim Saddler. Quote Share this post Link to post Share on other sites
ToddB 68 Report post Posted October 21, 2009 Hi Simply put. Right Handed Sewers should use Right Hand S Twist and the thread will maintain it's twist as you sew.. If you use Z Left twist it will unravel as you sew. If you're a Lefty use the Z. Have a try and you'll see what happens. Kindest Regards. Jim Saddler. Hi Jim ! I'm just getting started on my first leatherworking project (a complete newbie). I have designed a leather sheath for a 12" long digging tool. I have a vegetable tanned cowhide side section, approximately 9 oz. thickness and plan on hand stitching with Waxed Linen thread. I bought Al Stohlman's book titled The Art of Hand Sewing Leather , copyright 1977, and the instructions beginning on page #8 show using both hands with a needle in each hand. Since the illustrations show the right hand holding the awl, I would presume the worker is right-handed, but the left hand is also sewing with the same length of thread. Now, if that thread were a right hand S twist, that would be correct for the worker's right hand, but not correct for the worker's left hand. What will prevent the thread being sewn with the left hand from unraveling ? I'm no doubt missing something. Can you smarten me up ? Thanks, Todd Quote Share this post Link to post Share on other sites
jimsaddler Report post Posted October 21, 2009 Hi Jim ! I'm just getting started on my first leatherworking project (a complete newbie). I have designed a leather sheath for a 12" long digging tool. I have a vegetable tanned cowhide side section, approximately 9 oz. thickness and plan on hand stitching with Waxed Linen thread. I bought Al Stohlman's book titled The Art of Hand Sewing Leather , copyright 1977, and the instructions beginning on page #8 show using both hands with a needle in each hand. Since the illustrations show the right hand holding the awl, I would presume the worker is right-handed, but the left hand is also sewing with the same length of thread. Now, if that thread were a right hand S twist, that would be correct for the worker's right hand, but not correct for the worker's left hand. What will prevent the thread being sewn with the left hand from unraveling ? I'm no doubt missing something. Can you smarten me up ? Thanks, Todd Hi Todd Saddle Stitching is done with the 2 Needles, Right. If you are right handed you hold the Awl in yr Rt hand and a needle in each hand. A lfet hander will hold the Awl in his Left hand etc. What happens is when you push the Awl through the Leather you return the left needle into the hole as the Awl is withdrawn. without puting the Awl down you pick up the left needle and pull it through until about 5" of thread comes with it then you lay the Right Needle on the Thread and allow the needle to be withdrawn back into the hole where you can pick it up with left hand and pull the thread through. At this point I throw the left thread up and over the needle and pull both threads through and set the tension that makes for a neat stitch. The idea of throwing the left thread over is to from the same slope on back and front of the sewing, which looks much better and also forms a Knot inside the leather for extra strength. I hope that this is not too confusing for you. The good news is that I am in the middle of getting a new Workshop built so I'll have room to set up a clear section (old shop is crowded out) for taking Photo's of stitching etc. As soon as I can I'll get a set done showing all the proper steps and post them. Please have a Happy Day. Kindest Regards. Jim Saddler. Quote Share this post Link to post Share on other sites
ToddB 68 Report post Posted October 22, 2009 (edited) Hi Todd Saddle Stitching is done with the 2 Needles, Right. If you are right handed you hold the Awl in yr Rt hand and a needle in each hand. A lfet hander will hold the Awl in his Left hand etc. What happens is when you push the Awl through the Leather you return the left needle into the hole as the Awl is withdrawn. without puting the Awl down you pick up the left needle and pull it through until about 5" of thread comes with it then you lay the Right Needle on the Thread and allow the needle to be withdrawn back into the hole where you can pick it up with left hand and pull the thread through. At this point I throw the left thread up and over the needle and pull both threads through and set the tension that makes for a neat stitch. The idea of throwing the left thread over is to from the same slope on back and front of the sewing, which looks much better and also forms a Knot inside the leather for extra strength. I hope that this is not too confusing for you. The good news is that I am in the middle of getting a new Workshop built so I'll have room to set up a clear section (old shop is crowded out) for taking Photo's of stitching etc. As soon as I can I'll get a set done showing all the proper steps and post them. Please have a Happy Day. Kindest Regards. Jim Saddler. Jim, I'm not sure we are "on the same page". My post was regarding thread twist, as discussed in your post 10-06-2009 9:32 AM to MADMAX22, which I pasted below. _________________________________________________________________________________________________________________ Hi Simply put. Right Handed Sewers should use Right Hand S Twist and the thread will maintain it's twist as you sew.. If you use Z Left twist it will unravel as you sew. If you're a Lefty use the Z. Have a try and you'll see what happens. Kindest Regards. Jim Saddler. _________________________________________________________________________________________________________________ I also pasted my post below for your perusal. ________________________________________________________________________________________________________________ Hi Jim ! I'm just getting started on my first leatherworking project (a complete newbie). I have designed a leather sheath for a 12" long digging tool. I have a vegetable tanned cowhide side section, approximately 9 oz. thickness and plan on hand stitching with Waxed Linen thread. I bought Al Stohlman's book titled The Art of Hand Sewing Leather , copyright 1977, and the instructions beginning on page #8 show using both hands with a needle in each hand. Since the illustrations show the right hand holding the awl, I would presume the worker is right-handed, but the left hand is also sewing with the same length of thread. Now, if that thread were a right hand S twist, that would be correct for the worker's right hand, but not correct for the worker's left hand. What will prevent the thread being sewn with the left hand from unraveling ? I'm no doubt missing something. Can you smarten me up ? Thanks, Todd _________________________________________________________________________________________________________________ So Jim, with reference to my above paragraph, beginning with "I bought Al Stohlman's book........", can you answer the question, i.e. What will prevent the thread (referring to Right Hand S Twist thread), being sewn with the left hand, from unraveling ? I do appreciate your description of the 2-needle process and especially the benefits of "throwing the left thread up and over the needle", etc.. Reading and understanding your description of the process wasn't confusing, but for me, doing it might be a challenge ! lol Your new workshop sounds exciting and I will be watching for the sewing photos ! Thanks and I look forward to your reply Jim. Best Regards, Todd Edited October 22, 2009 by ToddB68 Quote Share this post Link to post Share on other sites
Lippy Report post Posted January 3, 2010 The subject of thread twist is still puzzling to my tiny brain. First off, I've got several spools of English linen thread that is "reverse" twist. Is that the same as "left" or "z" twist? Second question, can someone please explain the physics behind why a "rightie" should use the "s" or "right" twist. Is it the insertion of the awl on the right or left side that makes the difference? Cheers & Happy New Year! Quote Share this post Link to post Share on other sites
nthe10ring Report post Posted February 15, 2010 I am right handed and have been looking for some right twist 5 cord linen an don't seem to be able to find it, most of the suppliers have 6 cord in either left or right. I havent used a lot of the linen but recently purchased a couple of small bits of 4 and 5 cord and like it. Mostly I have used synthetics and have been splitting and rounding a smaller thread form the larger fibre threads. Thanks Jerry Fisher Quote Share this post Link to post Share on other sites
RandyScott Report post Posted February 17, 2010 I am right handed and have been looking for some right twist 5 cord linen an don't seem to be able to find it, most of the suppliers have 6 cord in either left or right. I havent used a lot of the linen but recently purchased a couple of small bits of 4 and 5 cord and like it. Mostly I have used synthetics and have been splitting and rounding a smaller thread form the larger fibre threads. Thanks Jerry Fisher Campbell-Bosworth carries 5 cord left twist linen thread but not right twist - see this link: http://www.campbell-bosworth.com/catalog/index.php/cPath/6_71_73?osCsid=6funrp8ns28q5o8mgjeut4ef76 Quote Share this post Link to post Share on other sites
JDM Report post Posted August 6, 2011 (edited) I'm facing the same quandary as the original poster. I want Barbour 5 cord linen thread, but I've only found it available in left twist. Some say twist doesn't matter for hand sewing. A few say it does. I have a theory how both can be right. Many don't throw in an overhand knot where the threads cross. Stohlman's book doesn't say anything about doing so. They just pass the threads past each other. For them, I doubt thread twist matters. Those who do add in an overhand knot throw the thread "up and over" the needle as Jim mentioned previously. However, direction matters. If you are a righty and throw up and over from bottom to top and toward the direction of stitch travel, that is a clockwise motion around the needle as viewed from the left side. If you are a lefty and do the same movement in relation to the work (mirror image), that is a counterclockwise motion. If you throw "up and over" the other direction, reverse those. Left (Z) thread unravels when twisted clockwise. So, a right hander making clockwise "up and overs" is unraveling the thread. Or, at least has the potential to. I suspect the tightness of the holes, how waxed the thread is, and how much thread remains to be drawn up when the overhand knot is formed may also be factors. I'm not sure what thread to buy. I'd have to go up to 6 cord to get right hand twist. Edited August 6, 2011 by JDM Quote Share this post Link to post Share on other sites
jimsaddler Report post Posted August 7, 2011 Hi JDH Some time ago I wrote that I was experimenting with Braided Threads for Hand Sewing. Well I feel confident enough now to say that it is very useful for Hand Sewing. Also it overcomes the problem caused by S or Z twist. First a comment on the availability of "S" Twist or Right hand twist. There was a Barbours S twist made for Chain Stitch Machines, but I've not seen that for years. Also there was a Silo fine Thread made for fine Hand Sewing, Also extinct. That was not a worry as most good Saddlers made their Threads on the Knee to suit the job in hand. Now comes the worry of getting decent Linen Hemp in #15. The Dealers only carry #12 or Common, which are both too coarse for fine Threads. Your are nearly right about the throwing the "back Stitch" If it is not thrown the stitch will not look good in either S or Z just lay in a line and look very ordinary. But there is always the unravel effect on the Z twist that has to happen. I'm not going to start an argument about who's right, because Stolman does it the one way and do it another. Lets just say that when it comes down to the equality of Expertise being the same, the one who throws the back stitch will always win as the better Stitcher over the flat sewer. Now we come to the Braided Thread issue. Braid doesn't care about S or Z twist. I've been using several types in my work for a while now. and the result is quite acceptable. In fact in some cases is better. for example it doesn't get so dirty when sewing long runs, you only require a very short tab through the Needle Eye as it won't strip out when you pull the needle through the work. (when joining the needle to the Thread, 1" is enough). I have some beautiful Ritza Braid in 6mm, .8mm & 1.0mm. which is round in profile and lays in beautifully front and back like the old Silko used to. I am using this for my Fine sewing where the Best finish is required. 0.6mm White looks exceptional when used at #12 spi on Show Bridles and Head stalls. Also it goes very well through my CB 441 to match up at #10spi. for Show Harness. It is Stabilised, lightly Waxed and Siliconised Polyester. Then there is the MOX Waxed Braid I am using for general work in the same sizes. It works well also but lays flat in the Stitch, which makes the Stitch look coarser. The only drawback with these Threads is having to use 1 or 2 sizes larger Needle to ease the thread through the Awl hole. Also needing a fraction heavier Awl Blade to cope. Lasting ability I am yet to find out so as to compare them to Linen? I'll let you know in 40 or so years the results. Down-side on the Ritza, is harder to thread in the 0.8 and 1.0mm. as it's very hard laid. But persevere and with practice you'll get the hang of it. Up-side is Neater stitching especially if "you throw the Back Loop"! Knotting off at the ends is probably best done with an extra back stitch as the thread is a bit slippery, same goes for starting. None of mine has come undone as a result. Well I'd better get off and let someone else have their say now. By the way nothing beats a good Waxed End in #15 patent Hemp for Hand Sewing. It's easier to use with finer Needles and Awls. Kindest Regards. Jim Saddler. I'm facing the same quandary as the original poster. I want Barbour 5 cord linen thread, but I've only found it available in left twist. Some say twist doesn't matter for hand sewing. A few say it does. I have a theory how both can be right. Many don't throw in an overhand knot where the threads cross. Stohlman's book doesn't say anything about doing so. They just pass the threads past each other. For them, I doubt thread twist matters. Those who do add in an overhand knot throw the thread "up and over" the needle as Jim mentioned previously. However, direction matters. If you are a righty and throw up and over from bottom to top and toward the direction of stitch travel, that is a clockwise motion around the needle as viewed from the left side. If you are a lefty and do the same movement in relation to the work (mirror image), that is a counterclockwise motion. If you throw "up and over" the other direction, reverse those. Left (Z) thread unravels when twisted clockwise. So, a right hander making clockwise "up and overs" is unraveling the thread. Or, at least has the potential to. I suspect the tightness of the holes, how waxed the thread is, and how much thread remains to be drawn up when the overhand knot is formed may also be factors. I'm not sure what thread to buy. I'd have to go up to 6 cord to get right hand twist. Quote Share this post Link to post Share on other sites
JDM Report post Posted August 9, 2011 Your are nearly right about the throwing the "back Stitch" If it is not thrown the stitch will not look good in either S or Z just lay in a line and look very ordinary. But there is always the unravel effect on the Z twist that has to happen. I'm not going to start an argument about who's right, because Stolman does it the one way and do it another. Lets just say that when it comes down to the equality of Expertise being the same, the one who throws the back stitch will always win as the better Stitcher over the flat sewer. I agree about the overhand knot or whatever it may be more properly called. I'm new to sewing and wasn't sure whether to make the knots as I establish a sewing technique. Hell, it took me long enough to even figure out some are even using them. After a little experimentation, I found my stitches look nicer and more consistent with the knots. I get an even, down to up thread pattern on the face side (\\\\) with the corresponding opposite on the back (////). Plus, the knot should help hold the stitching in place better if a thread breaks -- at least in theory. FWIW, I've been stitching as shown here: http://www.britishbl...-with-2-needles (I had to click on the "show" tabs above each picture to load them.) She seems to be using Z twist (left hand) thread. I am not convinced that twist direction makes much, if any, practical difference in hand sewing for most makers of small items, though I see how it can. However, I have very little experience yet with this stuff, so for now I'll defer to the few who say right twist is best for a right hander. I'd rather err on the side of caution. Good linen thread isn't cheap, and one spool (about 1000 yards in 5 cord) will last me many years, perhaps even the rest of my life. Whether thread twist becomes an issue due to the direction the knots are thrown or from building a twist gradually even without them due to the general mechanical-like repetitive consistency desired when hand stitching one awl hole at a time, I gather that twist can be an issue when sewing "old school" -- one awl poke at a time. Since I want to learn to sew that way, thread twist is a consideration to me. For fellow newbies wondering how to determine a thread's twist by sight: Look at the thread held vertically. If the spirals go in the / direction, which resembles the middle of a Z, the thread is Z twist (left). If in the \ direction, as the middle part of an S, it is S (right). Now we come to the Braided Thread issue. Braid doesn't care about S or Z twist. I've been using several types in my work for a while now. and the result is quite acceptable. In fact in some cases is better. for example it doesn't get so dirty when sewing long runs, you only require a very short tab through the Needle Eye as it won't strip out when you pull the needle through the work. (when joining the needle to the Thread, 1" is enough).I have some beautiful Ritza Braid in 6mm, .8mm & 1.0mm. which is round in profile and lays in beautifully front and back like the old Silko used to. I am using this for my Fine sewing where the Best finish is required. 0.6mm White looks exceptional when used at #12 spi on Show Bridles and Head stalls. Also it goes very well through my CB 441 to match up at #10spi. for Show Harness. It is Stabilised, lightly Waxed and Siliconised Polyester. Then there is the MOX Waxed Braid I am using for general work in the same sizes. It works well also but lays flat in the Stitch, which makes the Stitch look coarser. How much tab/tail do you leave behind the needle when using linen thread? When attaching the needle, which part of the thread do you stab it through? Some poke the needle hrough the tail or loose end, others go through the working end. I did a quick search on these brands of braided thread and didn't find any place selling them in the U.S. One (Ritza?) is made in plain waxed and waxed with silicone added. For hand sewing, is the silicone counterproductive (too slippery)? Do you apply hand wax (beeswax/rosin) to help "sticky" it up? The only drawback with these Threads is having to use 1 or 2 sizes larger Needle to ease the thread through the Awl hole. Also needing a fraction heavier Awl Blade to cope. I gather that the ends can't be scraped down to taper. Why not? Lasting ability I am yet to find out so as to compare them to Linen? I'll let you know in 40 or so years the results. You mentioned in a previous post having bad experience with early polyester thread, as well as some examples of the longevity of properly waxed linen (http://leatherworker...indpost&p=97256). I'm not a traditionalist, but I am somewhat hesitant to embrace new products and methods that don't have a track record. Newer is often, but not necessarily, better. Aluminum wiring in the 1970's. Ugh. Different types of plastics used for water piping in recent decades instead of copper, some of which have failed badly. Various newer drugs causing injuries and deaths. And on and on. For hand sewing, I'm leaning strongly in favor of good quality linen. Sort of like going with copper water pipe instead of plastic. Not the cheapest , and likely not the ultimate solution, but time tested, proven and solid. By the way nothing beats a good Waxed End in #15 patent Hemp for Hand Sewing. It's easier to use with finer Needles and Awls. Still being damp behind the ears to all of this, I don't know what you mean by "waxed end." Can you elaborate? I found Barbour 5 cord right hand thread in natural color (U.S. made) on ebay and bought a spool today. $56ish. The box shown indicates a "soft" finish vs. the "polished" sold at campbell-bosworth. I have been told that "soft" will better accept wax than "polished.". The seller has one left in case anyone else is interested. Jay Quote Share this post Link to post Share on other sites
Les No6 Report post Posted August 16, 2011 I'm a third generation harness maker in England my granddad dealt wholly with work gear this equipment spends its time either being worked hard on a very large horse or laying on the stable floor (wasn't the beautiful smell of leather you was greeted with when you entered his workshop most of his work being repairs in this type of work) this harness was hand stitched with hand spun linen thread (most called it hemp but its linen and was cheaper than ready spun thread) waxed with black wax and I've seen sets of harness around 100 YEARs old still in use no sign of thread rotting also seen items where the entire top and bottom of the stitches have completely worn away and it's still holding together as far as I'm concerned that's tried and tested so its linen for me but silk was supposed to be best never used silk don't know anyone that has. I do use braided polyester ready waxed on some jobs like sewing box keepers where their isn't enough room to use needles wouldn't use it to sew anything that will be exposed to sun light though I've seen it rot nylon in acouple of years, polyester is probably same, it do's hold up well to hand sewing. As to the subject of twist I asked my dad this many years ago and he said that thread twist only makes a difference to machines, before the advent of machine's twist wasn't an issue have known him to be wrong on occasion though. I'm right handed and use z twist same as I use on the machine a lot of hand stitching I do is continuing on from machine stitching so needs to match, on occasion that I make a thread I don't pay attention to the direction of twist and I've never noticed a problem I don't slant my stitches though that's an American thing we like ours neat and in line and English is regarded as best;), don't lock every stitch by passing the threads over each other I just do this at the ends or maybe it only shows up on long runs, Ill have to hand stitch a pair of traces and see. Quote Share this post Link to post Share on other sites
jimsaddler Report post Posted August 16, 2011 Hi Les I can appreciate what you are saying. Can I please point out a couple of point though. When closing out Machine sewing it is a good idea to sew in the same Reverse twist as the Machines for neatness. I did the same until I came into the age of the 441 with reverse which will sew my ends and reverse lock them. I even have the reverse pricking Irons to mark the reverse stitch rows to match the Machine sewing. Like you I like the way that good waxed end stitching will last for ever even if the back and front wear off. Reason being that the stitch is thrown , thus creating a twist inside the Awl hole like a screw and the Wax / resin / pitch bonds to the Leather like concrete. Yes the old boys did through the back loop back as far as I can trace in England, Scotland and Australia. I used to have Fine Carriage Harness that was made in the very early 1800's in London for a Maharajah. Well worn but holding up exceptionally well for its age. I unpicked a section and low and behold it was the same Twist as I use to-day. The Thread was was White waxed Silk! (not used to-day as the white was achieved by using White Lead in the Wax. A toxic mixture, we now realize why the Pro Stitcher's died young and Bald. I repaired Sulky Traces that my Great Grandfather made in 1927. To unpick the Linen stitching was was very hard to do as the thread was bonded to the Leather. The set of Harness had been regularly used at least weekly over the years. I still use the same Beeswax / Resin mixture as he did and I have Harness I made near 50 years ago still going strong and winning in the Show ring. So as far as synthetics go it will take me another 30 or 40 years to make up my mind if they are any good or not. I have to disagree about the Z & S twist though. only lefties should use Z twist as a right handed sewer will definitely cause unraveling, over a distance it causes the appearance to become straight instead of maintaining the Twisted lay appearance. To the casual observer it is not apparent, but for those who have long experience it is very obvious. To-day who cares? The standards have dropped. It's a throw away world they say! That is the problem we should all care and restore the Pride of our Forefathers who really cared about what they produced. Sorry I am not being critical, My thing is History of the Saddle and Harness Trades and I have always admired the beautiful Hand Stitching practiced in the British Isles. The slope is what makes it what it is. I've had visits from some of the Wallsal Hand Sewing Families over the years when I was in Tonga. One Family who spent a week with us. consisted of Granny, Mum and 3 Daughters plus little Brother. Their Family could not remember any ancestors who weren't Contract Hand sewers. All threw the Back stitch. Even when doing single needle. I might add that I have seen one Family Business here in Australia who never threw the Back Stitch. When it came to a National Product Competition, some 20 years ago, my Stitching won me the prize the (British) Judge explained. Yes every Thread was Hand Made on the Thigh. Kindest Regards. Jim Saddler. From Australia. I'm a third generation harness maker in England my granddad dealt wholly with work gear this equipment spends its time either being worked hard on a very large horse or laying on the stable floor (wasn't the beautiful smell of leather you was greeted with when you entered his workshop most of his work being repairs in this type of work) this harness was hand stitched with hand spun linen thread (most called it hemp but its linen and was cheaper than ready spun thread) waxed with black wax and I've seen sets of harness around 100 YEARs old still in use no sign of thread rotting also seen items where the entire top and bottom of the stitches have completely worn away and it's still holding together as far as I'm concerned that's tried and tested so its linen for me but silk was supposed to be best never used silk don't know anyone that has. I do use braided polyester ready waxed on some jobs like sewing box keepers where their isn't enough room to use needles wouldn't use it to sew anything that will be exposed to sun light though I've seen it rot nylon in acouple of years, polyester is probably same, it do's hold up well to hand sewing. As to the subject of twist I asked my dad this many years ago and he said that thread twist only makes a difference to machines, before the advent of machine's twist wasn't an issue have known him to be wrong on occasion though. I'm right handed and use z twist same as I use on the machine a lot of hand stitching I do is continuing on from machine stitching so needs to match, on occasion that I make a thread I don't pay attention to the direction of twist and I've never noticed a problem I don't slant my stitches though that's an American thing we like ours neat and in line and English is regarded as best;), don't lock every stitch by passing the threads over each other I just do this at the ends or maybe it only shows up on long runs, Ill have to hand stitch a pair of traces and see. Quote Share this post Link to post Share on other sites
ramrod Report post Posted August 16, 2011 i'd love to pick it up - i just don't have coin right now. someday, i'll stitch with linen. until then, i have miles and miles of polyester to use up. Quote Share this post Link to post Share on other sites
JDM Report post Posted April 30, 2014 (edited) I know this is an old thread. I'm getting back into leatherwork, and this mystery of thread twist for hand sewing mattering or not continues to bother me. So, I paid close attention while sewing without setting the awl down. I mean Stohlman instruction book style, except throwing the left side thread over (clockwise as viewed from the left, off side of the piece) to create an overhand knot, as I do and Jimsaddler and others advocate. I am right handed. I am unsure whether "throwing the loop" over makes any difference to twist tightening or loosening. I could argue that issue both ways as well as neutral. However, I noticed that juggling the awl and needle back and forth in my right hand, at least the way I do it, which is whatever comes naturally, tends to wind the thread in a clockwise from thread end (right twist) direction. So do minor hand rotations when pulling stitches tight, particularly when deliberately pulling the right hand side slightly downward and the left upward, as you would want when "throwing the loop." I can see where this could add up over a long thread run. A portion of a rotation or so each stitch could make a difference. Best would be to be tightening the twist, not doing the opposite. Is this effect enough to matter? Maybe or not. I suspect few still hand sew one awl poke and stitch at a time, and for those who don't, I doubt any of this really makes much difference. It may not either for those who do depending on their particular technique. Edited April 30, 2014 by JDM Quote Share this post Link to post Share on other sites
gary Report post Posted July 18, 2016 http://abbeyengland.com/Store/CategoryID/432/Level/a http://www.leprevo.co.uk/threads.htm Or try one of these (there are at least 6 more pages of links) Bonded Nylon Thread Sale - Up To 70% Off Bonded Nylon Thread. Ad · Bonded-Nylon-Thread.catwalk.co.uk Up To 70% Off Bonded Nylon Thread. Compare And Save. Home & Kitchen at Amazon - Low Prices on Home & Kitchen. Ad · www.amazon.co.uk/home Low Prices on Home & Kitchen. Free UK Delivery on Eligible Orders Get ad-free access to over a million songs with Prime Music Barlow's Tackle Express | BarlowsTackle.com Ad · BarlowsTackle.com Rod Wrapping Thread, Reel Seats, Handles & Guides. Free Catalog. Bonded Nylon Thread Sale | idealprice.co.uk Ad · idealprice.co.uk/sale Up To 70% Off Bonded Nylon Thread Bonded Nylon Thread. Compare STRONG BONDED - NYLON SEWING THREAD - Amazon.co.uk www.amazon.co.uk › … › Art & Craft Supplies › Thread › Sewing strong bonded nylon sewing thread by mm. 60s (tex 45), 4000 metre spools. rot proof and resistant to abrasion. choose from a variety of colours. Bonded Nylon Thread | eBay www.ebay.co.uk/bhp/bonded-nylon-thread Find great deals on eBay for Bonded Nylon Thread in Thread for Sewing. Shop with confidence. bonded nylon thread - eBay UK www.ebay.co.uk › Search › bonded nylon thread Find great deals on eBay for bonded nylon thread bonded nylon thread 30. Shop with confidence. bonded nylon thread - from UK thread company Somac Threads www.somac.co.uk/bonded_nylon_thread.html Bonded Nylon Thread. Manufactured from nylon 66, our bonded nylon has high tensile strength, is chemically stable and rot-proofed. A bonded nylon thread is ... Bonded Nylon Thread - PT Winchester www.ptwinchester.co.uk/bonded-nylon-thread We supply a comprehensive range of bonded nylon thread to a variety of industries that are highly resistant to extreme weather conditions. Call us for more info. Bonded Nylon Thread - stores.ebay.co.uk stores.ebay.co.uk › jimtalyinc › Sewing Thread 121 results found: Light Purple Bonded Nylon sewing Thread #69 T70 Upholst... · 2 spool Black & White Bonded Nylon sewing Thread #92 T9... · 2 spool Black & … Bonded 40 Nylon Threads choice of ... - ACE SUPPLIES UK LTD www.acesupplies.co.uk/acatalog/bonded-nylon-threads.html Bonded Nylon Threads at ACE Estimated needle size: 40 thread 100/120 - 60 thread80/100 40s thread is the most universal thread, its benefits are: BONDED NYLON SEWING THREAD - Amazon.co.uk www.amazon.co.uk › … › Art & Craft Supplies › Thread › Sewing bonded nylon sewing thread - rot proof - 60s - tex 45 - 500m (metres) - mm brand - various colours including black, white, red, cream, blue, pink, green, yellow, grey ... Braided cords and Industrial sewing threads, Staffordshire ... www.worthingtonindustrialproducts.co.uk Worthington Industrial Products is a Staffordshire UK based company manufacturing Braided Cords, industrial sewing threads, bonded nylon thread and polyester tapes Sewing Threads - PT Winchester www.ptwinchester.co.uk/sewing-threads Take a look at our range of industrial sewing threads made using various materials including polyester/cotton, bonded nylon and more. Call us for more info. Bonded Nylon Thread Sale - Up To 70% Off Bonded Nylon Thread. Ad · Bonded-Nylon-Thread.catwalk.co.uk Up To 70% Off Bonded Nylon Thread. Compare And Save. Home & Kitchen at Amazon - Low Prices on Home & Kitchen. Ad · www.amazon.co.uk/home Low Prices on Home & Kitchen. Free UK Delivery on Eligible Orders Get ad-free access to over a million songs with Prime Music Quote Share this post Link to post Share on other sites
