Members Yanni Posted June 4, 2013 Members Report Posted June 4, 2013 I have a SEIKO LSW-8BL, I think is similar to the Consew 255RB. http://www.industria...onsew_255rb.pdf The stitch length on the reverse is shorter than on forward stitching. We are making expensive leather bags here in the UK and need to backstitch at same length as on forward stitching. Is this possible as I get contradicting opinions. Thanks... Quote
Moderator Wizcrafts Posted June 5, 2013 Moderator Report Posted June 5, 2013 I find that by adjusting the inside foot to meet the feed dog slightly after the needle passes below the top of the dog, the reverse stitches more closely match the forward ones. I do this with no material under the feet. Try altering the point at which the inner foot makes contact with the leather, in relation to the tip of the needle making contact. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members ArtifactBags Posted June 26, 2013 Members Report Posted June 26, 2013 Wizcrafts, I remembered this thread from awhile back and just used it this morning to fix an ugly backtack on one of my Consews. Your posts have gotten me out of so many binds with my machines, and I want to thank you for your generous machine wizdom. --Chris Quote Twitter: ArtifactBags Instagram: Artifactbags
Members Gregg From Keystone Sewing Posted June 27, 2013 Members Report Posted June 27, 2013 (edited) See attached image below, this is under side of Seiko LSW-2BL (AKA Consew 255RB). Keep in mind, Maximum stitch length is 6.2mm (1/4"). Here is how to adjust; Set the stitch length dial, or push button for stitch length on the bed, depending on your subclass model, to the longest possible stitch. Loosen the lock nut on the threaded screw that you want to adjust front or back (as seen in image attached). Make sure that the machine is not stitching more than the maximum 6.2mm, or you will not be able to balance the stitches so they are the same front to back. If you want to be as precise as possible with this adjustment, we use a piece of cardboard to run the needle through without thread, and then use a micrometer to measure distance between holes in the cardboard. Once set properly, tighten the lock nut, and make sure the adjusting set screw does not turn while you tighten the lock nut. This should give you the best chance to get things working properly. Hope this helps. Cheers. Edited June 27, 2013 by Gregg From Keystone Sewing Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Yanni Posted November 21, 2013 Author Members Report Posted November 21, 2013 WoW...Fantastic...just seen your thread Gregg...a million thanks. I will try this at work hopefully tomorrow. Do you have a guide for a PFAFF 335 or an Adler 269-373 too to adjust front and back stitches? Happy to pay for the advice if that helps!....will make our leather bags look so much more professional. Quote
Members Brakewaite Posted January 30, 2025 Members Report Posted January 30, 2025 I’ve got a Consew 255RB-3, my front stitch and back stitch are different lengths how do I get them even again. Example when my front stitch is 4 stitches per inch my back stitch is 6 stitches per inch Quote
Members Damas Posted January 31, 2025 Members Report Posted January 31, 2025 On 6/4/2013 at 1:55 PM, Yanni said: We are making expensive leather bags here in the UK and need to backstitch at same length as on forward stitching. That won't solve your issue but here in France, we are doing backstitch by hand on expensive leather bags/items sewn with machines Quote Mitsubishi DU-105-22 - Singer 17-30, 45K25, 132K10 - Adler 30-1 and 069 - Pfaff 545 - Pearson #6 - Hightex CB3200 and CB243
Members shoepatcher Posted January 31, 2025 Members Report Posted January 31, 2025 The stitches have to be equalized. The mechanics manual for the 255 should be able to walk you thru the adjustment process. I do not have that manual. glenn Quote
