Everything posted by jasonsmith
Angelus 600 acrylic finisher bubbles
jasonsmith replied to Historicalbeltworks's topic in How Do I Do That?
I guess I'll have to ask the leather suppliers if they put heat packs in with orders that have an acrylic sealer. Though my nearest Tandy is an hour away. -
I came across this foam roller at Wal-Mart in the hobby section. The foam is 3/8" thick on one side. Might could do well as a way to dye larger pieces of leather. Though may lose die to the foam unless you could squish it out and back into the bottle via a funnel. But will experiment using it to spread a thin layer of pure neats foot oil on the grain side a day or so after dying: Hello Hobby 2 Pc Foam Paint Brush Set with Handle, 2.25" - Walmart.com
Recommend a permanent low sheen sealer
jasonsmith replied to jasonsmith's topic in How Do I Do That?
Junior: Pregnancy ultrasound HD CLIP - YouTube -
It’s not armor. Just leather prop replicas with spots and some spikes. I’ve already used eco Flo satin sheen that worked fine 10 years on. Will experiment cutting it 50/50 with water. I use pro dye, so less chance of dye rub off. -
I don’t think I’ve been belligerent. I just don’t know how many ways I can politely decline to use a particular product that has nothing to do with this thread. Mop and Glo seems to be treated as a religion though. People are free to use it if they want. -
I'm not being defensive when I'm forced to repeat myself over and over again that I'm not going to use Mop and Glo when people keep talking about it after I said I'm not going to use it 3rd post into this thread. I think some here are treating Mop and Glo like a religion. And I don't have a reason to believe something like Eco Flo Satin Sheen is the same thing as Mop and Glo. Because they aren't really the same product as they are made up of different chemicals for different purposes. Just because both have acrylic in it doesn't mean they're the same thing. What "natural finish" do you use, or do you mean you don't put a finish on it? My products are arm and shoulder gauntlets that you tie off via paracord through grommets and have spots and spikes and other things on them. -
Then what exactly is the problem if I use Eco Flo Satin Sheen since you believe it's Mop and Glo in disguise? -
I was searching around the forum and saw someone mention a company called Alpha 6. They sell a few different types of sealers that are "matte". I'll probably contact them to figure out what the differences are between their different matte topcoats and may order one to try. If it is a true "matte" and not kind of glossy like Angelus Matte Finisher. AlphaKrylik Matte Topcoat 8oz ⋆ Alpha 6 Corporation AlphaFlex Matte Topcoat 8oz ⋆ Alpha 6 Corporation -
Did you ever get this figured out? I see you posted this in January. Did you buy any chance order this during the winter and had it shipped to you? I've read warnings that if these products freeze, then they may be ruined. So I have no idea how places like Tandy's orders this stuff, unless they stockpile in the fall to cover the winter. -
I'm thinking of getting a 3oz empty flip top bottle from Walmart. And use a syringe to remove 1oz of Eco Flo Satin Sheen and inject it into the empty bottle along with 1oz of distilled water. Shake it and run some tests to compared to Eco Flo Satin Sheet full strength. I may also buy a bottle of Angelus Matte Finisher and try out a 50/50 distilled water mix with that too. Has anyone done a 50/50 distilled water mix with Eco Flo Satin Sheen or Angelus Matte Finisher? I assume it wouldn't be any different than when people do a 50/50 mix of Resolene and water? -
Well, technically, aren't I already using Mop and Glo by some other's logic? I already have a new bottle of Eco Flo Satin Sheen, same as I used last time, which some say is just rebranded Mop and Glo. So, haven't I been using Mop and Glo the entire time then? I do plan to do a test where I cut Eco Flo Satin Sheen with 50/50 distilled and see what that does. Though I usually see people recommending the cutting with Resolene. -
I think I'll do a test where I mix Eco Flo Satin sheen 50/50 with distilled water like what people do with Resolene and see what that does. I've used Eco Flo Satin Sheen 100% in the past with good results, but had wanted to try some other things when I ordered more dye. Which I went ahead and ordered more dye. -
I'm not using Mop and Glo just like how you don't use Resolene. It's a choice I made and a choice you have made. I don't care what you say about Mop and Glo, I'M CHOOSING NOT TO USE IT. I'm only sticking with sealers that are traditional leather sealers, you don't have to agree with it. Also, a little bottle of leather sealer goes a long way. I only spread a thin layer on top of the leather. -
You must have written that right after injecting Mop and Glo directly into your veins! -
I'm fully aware it does both. But it's primarily marketed as a floor cleaner, which is why I referred to it as a floor cleaner. -
I didn't "change" my criteria after Mop and Glo was mentioned. I've only used sealer bought from a leather shop and wasn't aware of people using floor cleaner to seal leather. I only "clarified" my criteria after being suggested to use floor cleaner. I've not "refused" to believe anyone. People can have positive or negative experiences, it doesn't change the fact that I have no interest in experimenting, especially when we are talking about sealing $40 worth of leather and dye. Others can experiment. Mop and Glo can share a similar substance with another product, but that doesn't automatically mean that they can be substituted for each other. I see Mop and Glo has fragrances and other things added to it. I'd call that contamination for purposes of sealing leather. At the end of the day, is it enough to matter? Well that's for others to figure out. The question is, if someone gave you a free bucket of Resoline or Eco-Flo Satin Sheen, etc. would you be willing to clean your floor with it? Yes or no? Why don't you give it a try and let us know how it turns out? Buy a bottle and dump it in the middle of the floor and clean it and let us know how it turns out? This argument goes both ways. Make sure to take pictures. -
Thanks, yeah, just don't get why people want to keep harassing me page after page just because I opted not to use Mop and Glo. Maybe I should start another thread on this topic with this disclaimer: "Not interested in Mop and Glo, don't mention it. I'm sticking with products that are supposed to be used on leather". -
Do you put Mop and Glo on your pancakes? So funny how many people act like children just because I turned down using Mop and Glo as I wanted to stick with traditional sealers sold a leather shops. I think some people here have been drinking it. If anyone is upset because I'm not using your favorite product, then best keep that to yourself than come here whining about it like a baby. -
Okay thanks. I was reading inside the quote box and had assumed it was directed at me. -
I didn't argue with the answers. Someone suggested Mop and Glo. And I politely declined to using that product and instead stated that I wanted to stick with sealers that are sold at leather shops. Did people come in with suggestions for satin sealers that are sold at traditional leather shops, or did they come in arguing with me because I chose not to use Mop and Glo? This thread is about recommendations for satin sealers that are sold at traditional leather shops. Tell me, how many recommendations were given that fits that criteria? For the last time, I'm not using Mop and Glo. -
Is the veg tan tooling leather sold at "ST Leather" any good?
One thing that kind of concerns me is their fine print. Lots of weird disclaimers and things that I generally don't see. i.e. if your items are damaged during shipment, then they say you are on your own and you'd have to contact the shipping company. Which generally isn't the way that works. As the shipper is the one who has to file a claim or whatever. That's assuming there is insurance on the shipment. So, if I were to order a quart of dye, and it arrived smashed and leaking because it was packed poorly. Then I guess you'd have to contact the shipping company to see if they'd be willing to do anything. Though, I say they'd tell you to contact the shipper, which ST Leather already says that you'd be the one to have to contact the shipping company. Have read of some reviews of people getting things damaged during shipment because items were packed poorly. May just skip them, though was interested to see if their $6 a square foot of veg tan was either junk or a good deal.
