Bifrost
Everything posted by Bifrost
Thanks for explaining. Now I understand. I need to try this sometime and se which one I like best! And don't be sorry to point things out for me, I like lerning new stuff. Sometimes I think to much about the construction that I miss one obvious solution /Tommy
If you look at my picture you can see that there are more fabric layers if you count one card pocket at a time, which means it's thicker at the bottom of each card pocket than if you compare to cutting out single rectangles. If my picture is not the way you do it i'm sorry for missunderstanding /Tommy
Doing like that will make the lining to thick with 8 card pockets. Atleast with the fabric i,m using because if I understand you correctly this will add one extra layer of fabrics to each card slot.
I cut out 8 rectangular pieces from thin fabric and glue them behind the card pockets. This way a pocket is formed and the cards wont slip down. I made a quick picture in paint. Maybe it's better than my explanation or maybe it just confuses things /Tommy
Thanks all! The tooled part is 1.2 mm (3oz?) the interior is 1 m.m goatskin (2 1/2 oz?) /Tommy
Hi! I just finished this one. I made the background stamp myself from a steel rod (my first own stamp). I also made the box for the wallet with my logo on. /Tommy
Big Purse
Bifrost replied to Bifrost's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Tina: First i put a coat of super sheen on the flowers. Then I used Eco-flow antique tan over the whole thing. -
Big Purse
Thanks for all the kind words! LNLeather: Yes, I drew the floral design myself. Anacott Steel: To bend the edges on the side panels I first did a V-groove around the edge. Then I skived the leather to about 1/2 of the thickness of the leather on the outside of the V-groove. Then I added some water with a sponge on the V-groove, and finally folded the edges 90 degrees. Maybe the picture below helps. /Tommy -
Hi! Finally done with this one! I've been working with this on and off during the summer. First time I ever done something this big and the round handles was something I had never done before. I hope the customer will be happy with it. All critique is welcome. /Tommy
Hi! This is two wallets I made recently. The blue one is a customer order, hope hewill like it. The other one I just made for fun, probably going to sell it. /Tommy
Thanks for all the tips! They will probably help me alot. Except for the ear plugs maybe...I don't think my landlord likes the idea of going around in ear plugs all day Kind regards Tommy
Hi! I've gotten some complaint thats it to noisy when I'm tooling leather. Does anybody have any tips how to reduce the noise? All ideas are welcome. Kind regards Tommy
Hi! This is a small evening purse I just finished. I liked the way it turned out so I think i'm gonna make another one but in different colours. All comments and critique are welcome Kind regards Tommy
Hi! I wanted to make an iPhone case and decided to make a room for coins and some cards as well. Kind regards Tommy
Purses, Wallets And Necklaces
Thanks! Yes, they are hand stitched -
Green Gilded Wallet
I used gold leaf(brass) and not paint. And yes, it will crack a little bit when it's being used, but not so much I think. Below are the steps I used to prevent it from cracking and oxidizing (since I used brass and not gold it will oxidize) aswell as giving it an antique look. 1. Applied the brass 2. Waited 48 hours and then applied something here in Sweden called "Zaponlack", it's used to prevent metals from oxidizing. I guess almost any top coat that prevents metals from oxidizing will do. But I have noticed that if you apply this before 48 hours the top coat itself will crack the gold. 3. Waited 1 hour for the "Zaponlack" to dry completely and thenapplied antique 4. And finally i used super sheen to seal the antique. Kind regards Tommy -
Hi! This is a wallet I made. I have tried gilding before but it has alwayes turned out to glossy. But this time I applied som antique on the gilded areas and I think it turned out nice.
Hi! This was the first time I tried to make a wallet with this type of construction. I had some problems coming up with how I should make the gussets but I think they look good enough. Overall I'm pleased with the wallet and I will probably do more of the same kind in the future. Any critique is welcome. Kind regards Tommy
Some New Carvings, Leather Viking Helmet And Horns...
Bifrost replied to Tina's topic in Historical Reenactment
Wow, looks great! I really like the cernit clay figures. /Tommy -
Card Holder
Thanks Ken. Yes, the pockets are to deep. I will fix that on the next one I make -
Hi! A simple card holder I made some time ago. I'm pleased with the carving but I think I need to work more with the inside of the card holder. Kind regards Tommy
