Okay, I've been poking around the site now for a while and have learned a ton, but I also have lots of questions. Like...
Should I be using a stitching awl or stitching chisel?
Until now, I've been using one of several chisels (6, 2 and 1 points) I got from Tandy on everything I do. I've been using my awl (I got from Tandy) just to widen holes as I stitch so I can pass two needles through at the same time. It pointed, but far from sharp like what I hear about Bob Douglas awls. What am I missing here? When should I be using an awl or the chisel.
Getting Stitching Holes to Line Up?
What's the trick here? I think I've experimented every which way and cant say I've found the "right" way yet. If I punch holes first, they're less likely to lineup perfectly. But If I glue first, then punch holes, I have to go back over it with the dye again. Using the groover make it even more complicated and difficult to get things lined up.
Should I always use a groover?
I understand the groovers are used to recess and protect stitching lines. I've been doing it on EVERYTHING regardless of how it will be used because I thought 'that's just how its done'. After reading through the forums, I'm not so sure. Should I stop using the groover?
Why/when should I use an overstitch wheel?
I've been using it to layout holes around corners and curves. Should I be using it for something else?
If it helps... I primarily have been working with leather weights between 3oz and 9oz to make variety of large and small cases/bags, iPad sleeves, and wallets. I've been stitching everything hand using Tandy needles and what I think is 4oz waxed nylon thread.
Any help and suggestions you can offer are appreciated. Thanks.
- Odin
