Clintonville Leather
Everything posted by Clintonville Leather
  1. My machine was acting up on some Harness leather. Everything was dialed in tension wise and it just started stitching short and screwed up a belt. Was wondering if anyone had ever had that problem? Thank you in advance.
  2. Looks like the pics didn't attach
  3. I will give it a shot the shank is slightly longer but it seems it would peen over just the same.
  4. Does anyone know if the CS Osborne 5/8" line 24 snaps work with the Tandy hand press dies?
  5. Do you just want enough to make one? I have some 9mm.
  6. My local restaurant supply store has disposable gloves for $4.50 for 100.
  7. We went through the Black Hills, saw Mount Rushmore and Devil's tower nice land out there. I really liked South Dakota but found that people drove 80 miles to their neighborhood bar! A big change from being in a "big" city like Columbus, OH. Have a good weekend.
  8. That sounds correct JLS I believe if the feed dog plate hole was tighter it would look better. I'll try and experiment with it. I am imagining this experiment will result in busted needles. Or maybe I should just try and raise the feed dog a little and grind it down more since I lowered it a hair to eliminate those marks. What part of Iowa are you in? My buddy and I rode our bicycles to the West coast and Southern Iowa was a bitch with all those rolling hills. Super nice people though. Cheers! A gouge line certainly helped Ole South but it definitely has nothing to do with tension I got that adjusted per the manual.
  9. Hello, the tension is set properly. The needle isn't producing a clean exit hole, maybe such a tool does not exist. Imagine if you were saddle stitching and you only put your awl through a little bit or your irons didn't penetrate fully. That is what it looks like. The holes on the bottom are smaller than the holes up top. I bet that was why Bob said it looked better with 138 on the bottom.
  10. I am new to using a sewing machine. The needle I am using is an Organ DPX16DIA 160/23. I am using #207 thread top and bottom. The needle works just fine but on veg tan the back side doesn't look so nice. Granted, I took a long time to learn to get a clean saddle stitch. The top side holes look precise but on the bottom it looks like the needle exploded through the leather. Am I being picky, is there a nicer needle to use or is this par for the course?
