J W Craftsman
Content Count
65 -
Posts posted by J W Craftsman
Also, what would the value be on a machine like this?
Nice work. Those look great and I bet they're a pleasure to use too.
Thanks!
The price of the awls is $70 shipped in the US. The X acto knives are 35 shipped in the US for wood ones and 45 for resin ones.
If you mean the Starrett pin vise I purchase them from Amazin.
Showing off some of the tools I make. First is one of my awls with feature copper ferrule and slStarrett 162b pin vise. This one is made from curly anigre(and available if interested)
I also make custom X acto knives. I use these knives daily in my shop and the nicer hardwood handle is kite comfortable and just plain looks better! Takes standard X acto blades.
Snow seal gives a nice matte finish. You could also make your own by mixing beeswax and neatsfoot oil.
I have a question regarding finishes like this. I prefer the look of the wax finish over the shiny resolene finish. I also noticed it gives the leather an almost "pull up" charecteristic when using this finish. My question is. Since it's a mixture between wax and nf oil is there any further conditioned needed for the leather? Oil before the wax/oil combo. Oil after wax/oil combo or is oiling no longer necessary since your using a mix of oil/wax.
Also, is the oil/wax good as a finish just on its own?
I should add, I'm referring to more the wax/oil combo you rub on then melt into the leather with a heat gun.
Looks great Pam!
No not the split ring, the part attached to the wallet. Didn't know what it was called and if it was something Ryan used exclusively or if it was a readily available item.
Curly Anigre one has been sold.
Forgot to mention that each awl has a flat spot ground on one side for thumb placement and to prevent them from rolling off your workbench.
Newest addition to my lineup. Hand turned hardwood awls featuring Starrett 162b pin vise and copper ferrules.
First one is made from curly Anigre. This will not be a regular production wood choice. I have very limited quantity of this wood as most curly Anigre with this much figure is cut down and used for veneer. I was able to snag a couple pieces from my supplier.
This one is made from cherry burl and will be an permanent wood choice when ordering awls. Has great figured and will take on that great patina cherry wood is known for.
Like all my other pieces each one is sanded to 400g to give a super smooth feel and finished with antique oil for protection and to give the wood a nice hand rubbed look.
***Awls do not come with blades. With such a wide variety of blades available as well as sizes it also allows me to keep the cost of the awl down by allowing you to select which blade will work best for you
The awls are $75.00 shipped within the U.S.
These two are ready for immediate shipment.
All other orders please allow 2-3 weeks for delivery As these are made to order. Any questions please message me here or my email at jwcraftsman@gmail.com
Walnut tool rack
Tired of my tools being in drawers I wanted a way to keep them on my work table but I also wanted something nice to keep them in. I came up with this walnut tool rack.
Made from rough cut, air dried Pennsylvania walnut. I will all the lumber myself in my workshop.
The rack features 95 total holes, in 3 different sizes to handle a wide variety of storage options.
Rack measures 3.75" tall
7" wide 18" long. There is foam bottom on the inside to give a nice soft bed for your tools to rest on and reduce noise when tooling as well as felt feet on the bottom. I use Antique Oil as my finish to give the wood a nice soft finish.
The price of the rack will be $60.00 shipped within the U.S.
Does anybody oil first then dye? I've tried doing that and it seems to give me a more even coat when I apply my dye.
The green and silver burl with ambonya burl caps knife had been sold.
I was going through something's in my shop today and came across this faux antique glaze that I bought at lowes years ago.
The antique part caught my eye so I grabbed a scrap piece of leather and thought I'd give it a try.
Put a couple geo stamps on the leather quick then hit it with the glaze. There was no resist of any kind on the leather prior to applying the antique. I wanted to see the results on both the stamped area as well as how well it would dye just the straight leather.
I let it dry a few hours then gave it a coat of straight resolene to see if it would smear, streak, lift off etc. it didn't do any of those things and looks pretty good to me anyways.
Tomorrow I hope to try another test laying down some resist prior to applying the antique then coating it with a 50/50 water resolene to see those results.
So far it seems to me like it works well and could be an alternative to traditional antiques with the bonus of being able to be purchased locally. Will update with more results as I have time to try them. If you have any other test you'd like to see with this let me know and I will try it out.
Blade are replaceable. It's essentially an X-acto knife glued inside the wood then turned on a lathe. The handle material is Boxelder burl pieces and alumilite resin. It's originally used as a blank for making pens buy works great for this application too.
Yep these are turned on a mini lathe.
Looking For Info On This Consew
in Leather Sewing Machines
Posted · Report reply
Thank you for the info guys much appreciated!
