olandrea
Everything posted by olandrea
I also use normally Sedgwicks leather and their leather care, now for the first time I use Baker. Baker them self don't recommend any brand of leather care. The lather conditioner in your link has jojobaoil as ingredient. To be honest, I think there is no leather care with out some sort of oil in it.
I got this info from Baker "J. & F.J Baker & Co. Ltd’s leathers are Oak Bark tanned for strength and durability. When they require cleaning or ‘feeding’ we recommend wiping with a damp cloth, applying saddle soap and buffing with a cloth or soft brush, before leaving to dry naturally. Please do not use oil based leather feeds as these displace the greases in the leather and cause the fibres to dry out and degrade. When you receive your leather it will likely have a whiteish residue of dubbin on the grain side. This can be removed with a soft bristled brush such as used to shine shoes. " What would be non oil based leather care? All I found have at least some oil in it. Thanks
Hi I would like to sell my Krebs / Randall leathersplitter. The knife on this splitter is like new and was made by the German knife maker Schanz from Niolox steel which cost me 170€. The splitter is based in Germany but would ship world wide. 600€ plus actual shipping cost.
Hi, what would be the equivalent in color and size to the Ritz 25 0.6mm JK7 from sajou linen cable? Thanks
Yes it it was sold
http://leatherworker...showtopic=50464
If got a copy of the original technical drawings from the Krebs splitting blade and the angle is exact 20 degrees.
Is there some interest in a new blade for your Krebs leather splitter? I have a top knife maker who will make me a new blade for my Krebs splitter after the original measurements. He will use hardened Nilox steel 1.415.03 this is the top steel for knife makers. You can search on the net for Nilox steel blades. It should be better than the original blade. This is a one time opportunity. The cost will be 220$ + actual shipping cost for one blade. 50$ down payment is necessary. If you have questions send me a mail.
J.d. Randell Krebs Style Splitter Help Please Bruce Johnson
olandrea replied to olandrea's topic in Leather Tools
Bruce thank you for the info this helps. Do you mean I can still buy new blades from Campbell-Randall for my splitter? Any idea how much they are? Thanks Olaf -
No more help here with the measurements of the original blade and the screws? Thanks Olaf -
Thank you Bruce for you fast replay. That's what I thought about the blade. With the adjustment screw do you mean the screw which holding the blade? You are right the blade should be wider, the 3.5cm are to narrow. The splitter can't be used this way. Could you please provide me with the measurement from your blade? It look like I need a new one. Any ideas who could make me one? I guess this can't be longer bought of shelf. There are also two different screws witch one is the original on? And under the screw of the lever , should be there a washer? Thanks Olaf -
olandrea posted a topic in Leather Tools
Hi, I got my hands on a old J.D. Randell Krebs style splitter and would like to know if the blade is original. It looks pretty messed up and is only 3.5cm wide and 1cm thick. I hope Bruce Johnson sees this because I know he has one of this. Here are some photos: Thanks Olaf -
If you look at Abbey Waxed "Ritza" Polyester for hand sewing 0.8mm JK21 brown 500m is 30.39 pounds and the Tiger Waxed Polyester 0.8mm JK21 brown 500m is 25.38 pounds. All is the same but the Ritza is 5 Pounds more expensive! The Ritza 44 is listed at Abbey as "Ritza" Polyester Braided Thread Silicone coated for machine sewing DKR01
Could some one please so kind and explain to me the differences between Waxed "Ritza" Polyester Braided Thread and Tiger Polyester Braided Thread Waxed. I was always assumption that the Ritza 25 is the same as the Tiger thread and both where made by Julius Koch? If you look at the Abbey side there are differences in price? Thanks Olaf
I have to split ( pull through splitter) some lager pieces of bridle leather. From nearly 5mm down to 3.5mm. Is it more easy to split the leather when it is wet? Thanks Olaf
wtb a Marvin Deitz hand cranked splitter.
Pull Through Splitter, Maximum Width You Can Pull?
Maybe with a chase pattern leather splitter, because they have a thinner blade. But with my Osborne and bridle leather I can't do it. -
7.5" wide and 4 feet long! on a 8" pull trough. -
I have to split down some bridle leather from 4,7mm to 3,5m what do you think the maximum width you can pull even If you do this in several passes? I tried a width of 19cm and there is no way I could pull it trough! Thanks Olaf
Looking for 1" solid brass buckle tip. IAS used to have this but no longer carry this item. Thanks Olaf
Hi Tor, it is not a Osborn splitter it is a pull true splitter model, made around 1910 in Germany. The blade must be special made because the blade from Osborn would not fit this splitter. For me it is important to know what would be the best cutting angel on the blade? 20°? Olaf
Hi, if got a old 8" German leather splitter, some think similar like the old Osborne ones, but it came with out the splitting blade. I found a knife maker who is willing to make me one but I need the geometry of a good splitting blade. Could some one give me a idea how thick a good blade should be, the slant of the cutting edge, hollow ground yes or not? Thanks Olaf
Looking for a 8" leather splitter knife. Thanks Olaf
