olandrea
Everything posted by olandrea
  1. olandrea
    Splitter
    I'm looking for a Krebs style leather splitter. Thanks Olaf
  2. I need this info because I have to cover the flesh side (after I put it through my leather splitter) of a shoulder strap for a fly rod case that will be from time to time exposed to the elements. Normally I could use some wax but in warm temperature that could let marks on the clothes. Thanks Olaf
  3. I always just assumed the gum would be water soluble after it was dry, and need to be sealed with acrylic lacquer like resolene when using it on the back of a belt to slick down the belt or on the edge. Then I spoke to some one and he said he had just assumed the oposite: that Gum Trag was a final finish for the edge or the back of a belt and he had never sealed it and never heard of it softening if it got wet again. So is gum trag on edge or the back good enough for out door use on its own? Also can gum trag seal a edge dyed with Fibiengs oil dye if used on bridle leather? Any thoughts?
  4. Hi, what woulde be the right size for the Osborne 128 when working with 3.5mm lether? Thanks Olaf
  5. Hi, I'm looking for solid brass chicago srews with a large head & base 12mm or more and stem diameter 4-6mm. Also looking for trunk handle loop in solid brass. Thanks Olaf
  6. Hi Noah, what size and color have these horsehide butt strips? How thick are they? Thanks Olaf
  7. I spoke the last days with a lot of cobblers about thread . A lot of them use even on bespoked shoemaking poly thread this days. But still they use there self made handwax also on poly like Chuck sad, because handwax locks the thread and/or hemp threads tightly. Olaf
  8. Ok and who is selling it in the UK? Olaf
  9. Hi, is there a supplier for shoemakers wax / handwax or do I have to make this my self? Thanks Olaf
  10. Normally I would suspect that Sedgwick bridle butt would be weatherfast, but I must say the leather tube was more than 12 houers in the rain and was realy wet, may be this would happen with every dark leather and white thread after 12 houers in the rain. What would be a deep penetrating sealer? Will the leather still have this natural oily wax finish after the sealer? How is the lifespan of the poly thread compared to the flax sinew? Thanks Olaf
  11. What would be the best white thread for hand sewing leather that will stay white even the leather got wet after some rain? I had a very bad experience with Barbours waxed pure flax sinew, after the leather ( Sedgwick Bridle Butt) got wet the brown color of the leather soaked on some places in to the white stitching. It looks quite ugly after all the work I had with this fly rod case.Thanks Olaf
  12. I alway wet the leather prior bending but end up after the leather is dry with stains on the leather so what do I wrong? How can I remove this stains? Thanks Olaf
  13. What is bridle leather? And what is the differents between English bridle and Western bridel? Thanks Olaf
  14. Looks like abbey saddlery has the brown Babour only in 18/4 and 18/6 but not in 18/5. They have some 18/5 from Somac, did some one use this linen thread? Olaf
  15. I work with 5 cord, would this be 40/3 ?
  16. The problem ist that you find the Barbour's unwaxed thread only in natural color. So if would like to have it black or other colors you must dye it. But what kind of dye do you use for it? Thanks
  17. How do you give to the Barbour's linen thread color? Thanks
  18. Greg, could you send me link I cant find the Bieler Mfg ? Thanks Olaf
  19. What size and kind of needles do I need for hand stitchen havy leather around 3-3,5mm, with a 5 cord linen thread? Thanks Olaf
  20. Hi. Can I buy the Barbour red handle pure flax sinew only in natural color or are there other colors of this not waxed linen thread?Thanks Olaf
  21. I need 2" discs! The Osborne 2" punch is expensive 145,45$. Olaf
  22. Looks good, but will this cut 4mm leather?
  23. What is the best way to cut exact round discs from 4mm thick leather? Thanks Olaf
  24. To gat a idea how much would it cost to laser and how much by hand. And how good hold the laser engraveing when the leather item will be used outside and could be gat wet? Olaf
  25. Hi, is some thing like on the photos possible to engrave on leather or is this a laser job?
