Hi All,
I'm currently making two pads. One 8.5" sqr for a mouse pad and the other is ~12" sqr as a top/cover for a wire frame bookshelf used as a side table. For both I plan to line the underside/flesh side with suede. What I'm uncertain about is how the liner will effect the edge finishing process. For example, I've been beveling, sanding, and wet burnishing my edges before dyeing but if I do that I'll have a rounded edge on the bottom which I anticipate will make trimming the liner to the edge really hard.
So some specific question:
On a lined piece of leather when would you finish the edges, before lining or after?
If lining before finishing, anything to watch out for? Would a burnishing tool used on the edge scuff or mar the suede? Will the beeswax or other material stain the suede?
Once the liner is glued down, can I bevel both the veg tan and suede as I would just the veg tan?
If finishing the edge before gluing the liner, is there anything to watch out for?
Lastly, though it's not an edge question but it is about the pads, what can I do make them flat? I notice the leather curls up when drying and flipping it over mitigates that a bit. I also notice when I oil, adding that suppleness back to the leather tends to flatten it. Any other tips? When I glue the liner on, if I sandwich it between flat surfaces and put a weight on top, will that help to flatten the pad?
All advice is greatly appreciated.
