DanishMan
Everything posted by DanishMan
  1. Hi Matt. Good point - I will check it out. Cheers Soren
  2. Dear Friends Thank you for your advise. I think the problem is the starting torque. The engine instantaneously drives the skiving machine, and the clutch only engages the feed wheel. To get started puts a lot of stress on the motor. In general the bell knife moves smoothly, but is still fairly tough to drive. I got the chance to buy cheap a 1HP motor - I will put that on and see what happens. I will keep you updated in a week, when I get back from holiday. Kind regards DanishMan
  3. Dear Friends Recently I bought an old skiving machine. The manufacturer is danish, but all the parts seem to be more or less standard Fortuna stuff. The skiving machine had a three phase 380 volt, 0.55KW, 3/4 hp, 2800 rpm motor mounted. I replaced it with a single phase 240 volt, 0.55KW, 3/4 hp, 2800 rpm motor. As the motor is driving the machine directly - and the feed mechanism via a clutch, it takes a lot of torque to get it running. My 240 volt motor does not have enough power to run the skiving machine (at least to start with). Does anyone have any idea of the compatibility relationship between a single phase and three phase motor? Best regards Danish Man
