Willb2862
Everything posted by Willb2862
I apologize for the delay in getting these posted, been very busy with work. Here are both of the belts completed. I couldn't be happier with the results of the painting, amd im sure the kids will love them! Thank you for all the help!
- 19 replies
I am using acrylic brushes. Stiff bristles.
- 19 replies
AB, thank you! Grabbed the same palette today, and used your method. Paint stayed wet and usable even after 2-3hr break! The belts are turning out great, thank you again!
- 19 replies
First, thanksto all of you who took the time to post suggestions! I tried thefine tip markers anda paint brush tonight. The markers worked great on my scrap/test piece! Unfortunately, the color changed drastically when i tried it on the dyed belt. I then switched to a 10/0 brush and , as per the suggestion from ABH, reduced the paint. Worked fantastically! Here is a pic of where I'm at so far. I'll post more pics when the belts are completed. Thank you again to all of the great suggestions!
- 19 replies
Thank you all for the suggestions! I will try out a few this week and see how it goes. Ill be sure to post some pics of the outcome!
- 19 replies
Fantastic idea! Thank you
- 19 replies
I referenced in and earlier post about 2 belts im making for my children. As children tend to do, they want what they want, irrespective of Dad's ability (or inability) to preform the required tasks to make the thing! Both belts have stamping they want colored. One has butterflies and flower, one snowflakes. I have acrylic leather paint and tried very fine brushes on a scrap piece, it didnt go well. How would you tackle this? Could I use a solid "brush", like a rounded awl? The problem was, no matter how lightly I pressed, the paint still spilled out of the lines. I did not thin the paint, fyi. Thanks for any suggestions. Will
- 19 replies
Thanks guys. I went with 1/2" spacing on both belts (i was informed by my 4yo that he WILL be getting a belt for xmas too) and 7 holes. They are coming along nicely. I can say that 3/4" spacing would have been better, but i started on them before i saw your replies. I'll post pics when they are done.
There is always someone who has to take a great tip and point out that the obvious solution was right in front of us the whole time! Lol. Seriously, cant believe I never thought of that!
Are expensive whet stones worth it?
Willb2862 replied to Artificial Intelligence's topic in Sharpen it!
I should note that I go to the strop more frequently than I would if I use the stones every time, but it's a few seconds and back to work with a super sharp blade. -
Im new to leather work, but have been a handtool only woodworker for a few years now. I have a full compliment of hand planes, several sets of chisels, marking knives, ect. Creating and maintaining a very sharp edge is always on my mind. I have found the most efficient way, FOR ME, is diamond stones and a strop. I use a two sided stone (400/1000) to set my bevels and start to hone the edge. I then move to the strop untill the edge is fully pollished. After that, I only go back to the stones if I get a knick/chip in the edge, or to change a bevel angle. Other than those circumstances, I maintain the edge with just the strop. This has worked wonders for me by saving time and materials! As far as the burr created when sharpening, if your technique is good and the angle is consistent across the length, and no burr is being created, its probably due to the metal of the blade. Soft steel will burr up fast, but come off easily, sometimes with a fingernail when checking for the burr. Hard steel takes a while to burr and is harder to remove. Hope this helps someone. -
Thats a great tip! And I just so happen to have a beveler that needs sharpening! Thanks
I have made an 1 3/4 and an 1 1/2 belt so far. I have used the same spacing for the holes, buckle slot and snap placement on both. My daughter, who is 6, has asked for a belt for xmas. I am using lighter leather (4/5oz) and it will be 1" wide to fit in kid size pants. Im wondering how you guys would adjust size/spacing/placement of the holes. The two aforementioned belts are the extent of my leather crafting thus far, so any help is appreciated! Also, what size snaps would you recomend for a belt this size?
Thanks for the info Mike. Might I ask what you line your holsters with?
I was going to use kydex for the paddle. I like the slim profile of kydex and find the preformed ones fit my hip well and are comfortable for me. Thanks for the advice!!
Going try my hand at a holster for my 1911 in the near future. Being a newbie to the craft, I have been researching the process. Maybe I'm overly optimistic, but the process seems fairly straightforward for simple designs. Im struggling on selecting the proper weight leather however. I have seen recommendations run the gambit from 4/5 on up to 9/10. Perhaps my lack of experience is causing me to miss some nuance in the differnt holster designs that makes one weight work for a particular holster, but impractical for another. Im looking to make is a modified avenger style, using a paddle instead of belt loops. Again, for a full size 1911. I plan to incorporate a stiffener with a narrow strap across the back for mounring hardware, wrapping around to a traditional style stiffener on the front (1 piece). What weight leather would you recommend and why? If my neophyte status is causing to miss some obvious problem, please educate me! Thanks
Thanks for the warm welcome all! I have dabbled in blade smithing, and find it should be in a class all its own! I enjoy it, and have made some functional knives and a few declarative pieces. Mostly I make fuctional items such as hooks, tools, hard to find/obsolete parts, knobs and handles for my wood projects, ect. Im slowly falling down the blade smithing rabbit hole! Im currently between shops, hope to build a new shop in the spring. Half woodworking/leather, half blacksmithing/metal work. One the forge is burning once again, I'll be sure to post some pics. I will try to dig up some pics of old stuff in the interim.
Hello all. I am new to the forum and new to leather craft. Found this forum while looking up info on holsters. I found what i needed in short order! Leather is my latest hobby, i also do woodworking, blacksmithing, and metalworking. Looking forward to learning and sharing!
