Edsbear
Everything posted by Edsbear
  1. Also thank you for the needle/thread link
  2. Thanks for the advice, I will be giving what you suggested a go. The coats thread is Terko Satin is a cotton wrapped polyester core spun thread with a satin finish
  3. Bit of a problem if anyone can help please. I am sewing acrylic canvas and occasionally get a loop on top and getting a bit of pucker too, please see picture. I have adjusted tension, checked hook timing, stitch length etc I am now wondering if there may be a mechanical problem with the machine or is there something I'm missing. The machine is a Brother LS2 B837. Needle is a 19/120. Thread is Coats Tkt 036 Many thanks
  4. I thought VFD's were to control 3 phase motors if only single phase was available
  5. Thanks for the info, does your new motor creep in like a clutch motor
  6. Hi, I have a Brother LS-B837 industrial machine and added a sevo motor which is great apart from when starting to sew, the motor doesn't come in slow and smooth like the old clutch motor used to. When its running its slow enough but would like a smooth start instead of it jumping straight into the slowest speed which is quite slow. Does anyone know of a mod that will acheive a smooth slow start like a clutched motor does Thanks
  7. Thank you, yes I agree both Cechaflo and Sailrite are great channels but I am trying to French seam the top plate where it meets the boxing, so basically a top stitch on the top and a top stitch on the side boxing with the twin needle, maybe its not possible
  8. I am trying to French seam the border(border and top plate) of a seat cushion which is square. The problem is that when I get to the corner the stitches end up misaligned and don't go around the corner parallel so look rubbish. I wondered if anyone had some tips on this, its easy doing a 90 degree turn on a flat piece but this driving me mad at the moment. I am using a twin needle with split bar 3/8" gauge.
  9. Just to update that the bonded nylon thread solved the problem. thanks to the helpers here
  10. Thanks for your help, I have ordered some bonded nylon cones
  11. I must admit the left hand thread doesn't look or lay as nice as the right hand Some suppliers are saying use bonded nylon because its multi directional?
  12. Thanks for the info, I had no idea about that, I will try to get some
  13. Hi All, My Brother LT2-B835-3 is sewing ok but sometimes roughly every 10th or 20th stitch I get quite a big knot showing on the left hand underside, right side is fine. does anyone have any ideas what could possibly cause this please. Many thanks
  14. Thanks for your input everyone, much appreciated
  15. Hi, does anyone know what size drill and tap would be used for a Brother B837. I want to fit a binder attachment to the bobbin plate, some holes already in the bed seem to be the same thread as the presser foot screw but I can find the info. Many thanks
  16. Nice one fibersport such a simple thing causing so much grief. My machine is a large bobbin top loader but the cover plate is flat, no bumps. I am waiting for a new timing belt because it looks like it might be the original and has a bit of slop in it, I'm hoping this will help. The machine is not stitching too bad now but still has to have a lot of upper tension and very little in the bobbin.
  17. The base of my Brother B837 looks a bit different to the 211g156 but there must be something similar to adjust but cant see which bit Thanks everyone
  18. Thanks Quade, I have adjusted the reverse lever stop to make a bigger stitch but this doesn't make any difference. Still not the same as forward. I still cant find the adjustment to equalise forward and reverse stitch length
  19. Hi, My Brother LS2-B837 won't reverse into the same holes, the reverse stitch is smaller. I have adjusted the reverse lever stop to make a bigger stitch but this doesn't make any difference. Does anyone know if there is something else to adjust to balance the stitches Many thanks
  20. Thanks Garyak, I started from the beginning several times and bobbin is in the correct way but the upper tension always ends up really high and hook has to be retarded to get a decent stitch Cheers
  21. Thanks for the response, I though I was the only one... I cant retard the hook anymore because it will hit the needle eye area. I have tried various distances from the needle but still I have to use excessive upper tension. One thing I noticed today was the the timing belt seems slack and can easily be slipped off the gear and with the flywheel aligned with the marks on the machine the timing mark on the lower gear doesn't quite line up, seems about half a tooth out. I will order a new belt and hoping that will help. The belt looks original so maybe its about time it was changed. Machine is a Brother LS2-B837 Many thanks
  22. Hi, Can anyone shed some light on why my Brother B837 needs the hook timing retarded to sew, the upper tension also needs to be very tight. The hook needs to be right at the bottom of the needle scarf if the hook is timed by the book the bottom thread loops. Could this be a main timing issue or belt slip? Thanks
  23. My singer 201k will sew 3 layers of leather but if I want to sew 4 layers it seems to struggle with creating a nice stitch. My questions are: can I make this machine more heavy duty or do I need a walking foot machine can the maximum stitch size be increased by modifying Many thanks
  24. I have sewn a seat cover and the lighter leather colour under the top colour is showing between the stitches, Does anyone have an idea what's happening here please. Picture attached it explains it better. Many thanks
  25. Thickness is approx .056" (1.42mm) and 32"x20" straight sided
