Stephen111
  • Content Count
    6
Everything posted by Stephen111
  1. Steps to use a roof safety harness. Step 1: Inspect the roof safety harness kit. Step 2: Safely climb a steep roof. Step 3: Consider fall space. Step 4: Install roofing harness anchor points. Step 5: Set up the slide guard. Step 6: Put the harness on. Step 7: Attach to the fall protection system. Step 8: Keep a short distance from the anchor point.
  2. Leather comes from animal skin, which stretches over time. Of course, a leather belt can stretch between 1 and 3 inches with constant wear. However, the extension of the maximum duration takes 4 to 6 months.
  3. Ways to clean the bottom of shoes to make them appear fresh. Step 1: Make a paste of baking soda and soap. Step 2: Make use of white toothpaste. Step 3: Iodized salt and vinegar. Step 4: Remove nail polish using nail polish remover. Procedure 5: Make use of bleaching powder. Procedure 6: Laundry or dish soap.
  4. Step-by-step assembly of the electrician's tool belt. Step 1: Choose a sturdy belt with pockets of different sizes. Step 2: Hold your most important tools in your dominant hand. Step 3: Store less-used tools on the secondary side. Step 4: Add/remove or change pockets.Step 5 - Use braces to support the weight.
  5. Moc Toe boots used to be iconic boots for farmers and hunters. Nowadays people can wear moc toe boots for casual looks. We can recognize a pair of moc-toe boots by the toe cap with a U-shaped seam. The design of the shoe creates a spacious interior. We can use the shoes for different activities without hurting our toes.
  6. There are a few ways to stretch your leather belt that you can try. Method 1 - Add more weight. Method 2: Create 1 more hole. Method #3: Soak in warm water. Method 4: isopropyl alcohol.Method 5: Stretch the leather with heat. Method 6: Place in the freezer. Method 7: Use leather stretching products
