Members MackProvisions Posted May 25, 2022 Members Report Posted May 25, 2022 Hey everyone! I'm new to the forum. I would appreciate some help! I recently purchased a Singer 44-30. It's intended to do light leather (very light). All I can find online is the parts manual. I'm looking to find the actual manual to confirm needle size. I pulled the existing one out and it reads "BEKA 100/16". I'm assuming that's a 135x7....? Any help would be great. All the best, KC Mack Owner, Mack Provisions www.mackprovisions.com @mackprovisions Quote
CowboyBob Posted May 25, 2022 Report Posted May 25, 2022 A 16x2 should work. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members shoepatcher Posted May 27, 2022 Members Report Posted May 27, 2022 the singer book say it uses Singer Needle number # 2210-71. That is needle system #2220 which I have no idea what that one is. Go with Bob's suggestion. glenn Quote
Members Constabulary Posted May 27, 2022 Members Report Posted May 27, 2022 (edited) The 44 seems to be the short bed version of the Singer 31 / 31K. So I would go that route when looking for a manual. Major difference IMO is the bed size and the 44-30 seems to have a roller foot everything else IMO is like the Singer 31 / 31K. Edited May 27, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members MackProvisions Posted May 27, 2022 Author Members Report Posted May 27, 2022 On 5/25/2022 at 8:26 AM, CowboyBob said: A 16x2 should work. I bought some and will let you know if they work! Thank you. Quote
Members MackProvisions Posted May 27, 2022 Author Members Report Posted May 27, 2022 7 hours ago, shoepatcher said: the singer book say it uses Singer Needle number # 2210-71. That is needle system #2220 which I have no idea what that one is. Go with Bob's suggestion. glenn I saw that too and have no idea what that means lol. We'll see if 16x2 work! Quote
Members MackProvisions Posted May 27, 2022 Author Members Report Posted May 27, 2022 7 hours ago, Constabulary said: The 44 seems to be the short bed version of the Singer 31 / 31K. So I would go that route when looking for a manual. Major difference IMO is the bed size and the 44-30 seems to have a roller foot everything else IMO is like the Singer 31 / 31K. You're spot on - it's a short bed version of the 31's. It's actually the same dimensions as my 95-40. I can swap out heads no problem. The 95-40 takes 88x1 and just by comparing the needles to each other I know 88x1's are not going work. I'm not sure what 31 machines use? 16x87...? Quote
Members Constabulary Posted May 28, 2022 Members Report Posted May 28, 2022 I do not know the Singer 95-40 but 88x1 is a short serger needle - or not? Aren´t the Singer 95 / 96 and 31 using system 16 needles ex factory? I think the system 16 needles all have the same length. If it was me I would check if is possible to use the same needle in both machines (lets say System 16). Maybe you just have to adjust the needle bar height a little bit. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members MackProvisions Posted May 28, 2022 Author Members Report Posted May 28, 2022 On 5/25/2022 at 8:26 AM, CowboyBob said: A 16x2 should work. They indeed work! Quote
