Members Kulafarmer Posted December 15, 2015 Members Report Posted December 15, 2015 Really nice stamps, I just bought a bunch of craftool stamps to add to a small collection of vintage stamps i bought on Ebay, Not impressed, The new stamps sort of suck, really disappointed, especially at almost 10$ a piece, feel like that was the worst 450 i have spent in a long time, basket weave stamp is shallow, the other border stamps same thing, just dont have the detail, just look like more cheap chinese crap So whenever i can get some money again i guess im going to hit Barry King or find some others, just hard to spend 30-40-50+ on one stamp Quote
Members TLP Posted December 31, 2015 Members Report Posted December 31, 2015 How were you able to get the "cross thread" or "small diamonds" on the bottom? The cross hatching is called checkering, and is done with a special file, a checkering file. available from places like Brownell's, Indian Jewelers Supply, Rio Grande Jewelers supply and some of the larger machine shop supply companies. Quote
Members tardis86 Posted January 21, 2016 Members Report Posted January 21, 2016 Has anyone made any YouTube videos on the stamp making process? I've looked and haven't really found any Quote
Members genewshipp Posted February 22, 2016 Members Report Posted February 22, 2016 NICE!! Well done ghstrydr164. Off to the hardware store.... I'm thinking about a big rubber handle for stamps, large enough to make holding the stamp a little easier on the joints but not so big to obscure my line of sight. And make several of them with different size holes for all the sizes of my stamps. When done just pull it off and put it on the next stamp. Has anyone seen a stamp handle on the forum? I have started making my own Stamps and would like to share and have others that make their own Stamps share "How and What" they have made and are making. Quote
Members genewshipp Posted February 22, 2016 Members Report Posted February 22, 2016 Doc I used a file to make a dagger. After I heated it in the forge to a dim red, which I no longer have access to, I quenched it in water. No idea on the temp because it was fifteen years ago. It's so hard that I cannot sharpen it. Will more heat treating anneal it? If so I will probably use an acetylene torch and instead of a cutting tip, use one of those heating tips that has a humongous flame, does it need to be quenched after? If so, in water or oil? Thanks Gene This is an interesting thread, as I am a tool maker for a screwmachine shop. To justtouch on a couple of things here.I have seen several old tools made from plain steel. The staining you mention may befrom the type of tanning done on the leather you have IE: Veg vs Chrome.Stainless vs mild vs carbon steel. All steel has some carbon in it. Cast iron hasmore than steel. To make steel the carbon is removed from the iron, then addedback in at a certain percentage to get the correct alloy. Steel is graded by themajor alloying element IE; 10xx, 4xxx, 8xxx, etc. The last 2 digits tell you thecarbon content in points.1000 series steels are plain carbon steels.What you find a a box store is usually 1018 which is considered a low carbon steel.You generally need around 25 points of carbon to get any hardening effect. Files,some springs, etc are made with 1095 which is considered a high carbon steel. Withdifferent heat treating you can have a piece of 1095 be as brittle as a file, orflexible as a spring-cool how that works-huh?Chrome-moly steels like 4140 have 40 points of carbon, but the major elements beingchrome, and molybdenum make them very tough. These are used for things like shaftsfor equipment.Stainless steels (stain less than regular carbon steel) have high chrome, and nickelcontents. To be called a steel they do have some iron content.The 300 series are the most common; 303,304. 303 is a freer machining alloy than 304.Stainless steels are tough, not really hard. Mainly used when corrosionresistance/sterility is needed.316 is used for high corrosion applications like tomato processing, cookware, etc.400 series stainless steels are magnetic, and will stain faster than 300 series. 440C is used inknife blades.As for hardening. You can case harden bolts, nails etc at home by using a productlike Kasenite. Case hardening applies a shallow layer of extra carbon into the mildsteel allowing it to be surface hardened, This case will be from .003"-.010" deep dependingon how it is applied.high carbon steels can be just heated past magnetic (when a steel reaches thetransformation stage it loses it's magnetic properties) then quenched in water, oroil. Oil is a slower quench, and will cause less heat related cracking than waterwill.Only 400 series of stainless can be heat treated. 300 series can be work hardened.Stainless can be passivated in a citric, or nitric acid bath to remove the surfaceiron content left by machining, and improves it's corrosion resistance. Probablynot needed for leather stamps.Now for the second half here. One of the byproducts of the company I work for arebar ends. They run around 7" long, and are what is left over form the 12' bars westart with. We run a lot of stainless steel parts, so we have lots of stainlesssteel bar ends. The stainless is in diameters from .0625" (1/16)up to around .500"(1/2") sometimes larger. I have bought bar ends in the past for resale to othercraftsmen. I can sell you more material for what you folks are paying for bolts,.The USPS flat rate boxes work good for this. I am located in Southern Nevada. Wealso machine copper, brass, some aluminum, and copper beryllium alloys. The Copperberyllium alloys take special care when performing operations like grinding, andsanding as it is a inhalation hazard. Chronic exposure can lead to berylliosis. Onthe other hand it can be heat treated , and all manner of tools are made from it.If there is some interest I can put some bundles together, and get current scrappricing. Quote
Members TLP Posted February 24, 2016 Members Report Posted February 24, 2016 The dagger you made is currently very hard, but also very brittle. If you drop it on a concrete floor it may shatter. to make the blade less brittle you need to draw back the temper by heating your knife to 400 deg F. the blade will show a light straw color at which time you will requench to prevent overheating. The knife forums and sites will go into greater detail on the heat treating process. and you would be prudent to do a bunch of research before you draw back the temper. On a leather stamp I would heat the tool to red hot heat at which the steel becomes nonmagnetic, quench, then polish off all of the scale and oxidization. I would then heat the stamp from the end which is struck with the hammer/mallett. the color will start at straw and then go to the darker colors. you will then watch as the straw color travels down the length of the tool when the straw color reaches the head of the stamp cease heating and quench. you do not want to overheat the struck end and it will end up a purple color, definatly do not heat to red hot at this stage. You will end up with a differentially heat treated tool, the head will be hard with the shaft being softer. ALSO YOU NEVER STRIKE YOUR TOOLS WITH A STEEL HAMMER, IT WILL MUCHROOM THE SHAFT ENDS. Quote
Members genewshipp Posted February 24, 2016 Members Report Posted February 24, 2016 Thanks TLP! Quote
Members BIGGUNDOCTOR Posted March 9, 2016 Members Report Posted March 9, 2016 Sorry for the delay in responding, had some technical issues logging on. Tempering can be done in a toaster oven, and makes it easy to hit the proper temp. A file is close to W-1 tool steel - info provided by Nicholson's material guy who has 47 years with them. Heat treating covers austenizing (hardening) , tempering (drawing back), and annealing (softening). Heating past critical temp then quenching will fully harden. Depending on the steel alloy quenching is done with one of the following; air,water,oil. heating to a set temp after hardening will temper it. Tempering helps to reduce brittleness, internal stresses, and creates desired attributes. 1095 steel can go from brittle hard to being a spring with proper tempering. Annealing requires the steel to be heated to a critical temp then cooled verrrrrry slowly, or in the case of some steels at a very controlled rate in a furnace. For leather stamps I wouldn't even bother heat treating since even in a soft state they will be harder than wet leather. Plastic , and even wood has been used for some stamps. Quote You laugh at me because I am different. I laugh at you because you are all the same.
Members genewshipp Posted March 14, 2016 Members Report Posted March 14, 2016 Not a problem. Thanks Big Gun! Quote
Members Harry Marinakis Posted June 29, 2016 Members Report Posted June 29, 2016 (edited) I bought a large coil spring at the junkyard for about $3. I've been making a lot of punches and stamps, and I've barely used any of the steel. I just cut off, straightened and normalized another 15 inches, and can probably get at least another dozen stamps and punches from this piece of steel. I've been annealing the steel in vermiculite, and then using a Dremel tool to make the design. I use the stamps on both steel and leather, so I harden and temper. Edited June 29, 2016 by Harry Marinakis Quote
