Members ethereal Posted July 28, 2022 Members Report Posted July 28, 2022 Im wondering if anyone is aware of what the minimum and maximum thread sizes are for the Pfaff 145 Model H3? I saw another post on here mentioning that #207 was the highest the top could take, and #138 was the highest the bobbin could take, though Im seeing needles available for the H3 (size 134-135) on threadexchange that go up 200/25, which I believe can handle #277 thread as well. I also see needles that go as low as 65/9, which would be relative to #15 thread? Any help is appreciated as the Pfaff manual is a bit difficult for me to understand. Quote
Moderator Wizcrafts Posted July 28, 2022 Moderator Report Posted July 28, 2022 The min and max thread sizes depend on the build of your machine (hook, bobbin size, throat plate, take-up lever, feed dog, tension and pressure springs). When I had that model it was only good up to #138 thread, using a #160 needle. It also worked great with a #150 needle. I think you'd need a more recent version that includes the letter H on the model tag to run #207 thread. As for the minimum size, any thread smaller than Tex 50 and a # 14 needle might require a smaller hole in the feed dog and a closer hook to needle spacing. The thread tension spring might need to be lighter duty. My walking foot machines are all setup for medium to heavy duty sewing and #69 thread minimum. They eat cloth and just gobble up or break thin thread. I keep a Singer 31-15 straight stitch machine on hand to handle soft cloth, linings and wallet interiors. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members ethereal Posted July 28, 2022 Author Members Report Posted July 28, 2022 On 7/28/2022 at 1:44 AM, Wizcrafts said: The min and max thread sizes depend on the build of your machine (hook, bobbin size, throat plate, take-up lever, feed dog, tension and pressure springs). When I had that model it was only good up to #138 thread, using a #160 needle. It also worked great with a #150 needle. I think you'd need a more recent version that includes the letter H on the model tag to run #207 thread. As for the minimum size, any thread smaller than Tex 50 and a # 14 needle might require a smaller hole in the feed dog and a closer hook to needle spacing. The thread tension spring might need to be lighter duty. My walking foot machines are all setup for medium to heavy duty sewing and #69 thread minimum. They eat cloth and just gobble up or break thin thread. I keep a Singer 31-15 straight stitch machine on hand to handle soft cloth, linings and wallet interiors. Expand Ah that makes a lot of sense. Ive got an H3 and it is embossed onto the tag so I believe I should be good to try #207. A follow up question for your Singer, do you use that for sewing lining onto leather as well (for leather jackets, pants etc.), or would you use your walking foot in that case? Additionally, would you base the needle you would use on the lining fabric, or the leather? Quote
Members Johnny Posted July 28, 2022 Members Report Posted July 28, 2022 (edited) I have a 145 H4 that use's 190 Needle System, it sews fine with #207 Both top and in the bobbin. I have never used any thread smaller than #92. Not sure about #277 thread that might be pushing the limit for these machines. I used to sew mostly belts with mine but don't use it much any more once I got my CB4500 setup with the narrow needle plate. Here is a belt I made using #207 thread and a size 24/180 needle. Johnny Edited July 29, 2022 by Johnny Quote
Members Johnny Posted July 28, 2022 Members Report Posted July 28, 2022 Here is the back side, great machines my only complaint is the small bobbin. Quote
Moderator Wizcrafts Posted July 29, 2022 Moderator Report Posted July 29, 2022 On 7/28/2022 at 7:32 PM, ethereal said: A follow up question for your Singer, do you use that for sewing lining onto leather as well (for leather jackets, pants etc.), or would you use your walking foot in that case? Additionally, would you base the needle you would use on the lining fabric, or the leather? Expand I only use the 31-15 to sew non leather materials together. If I need to sew a lining into something made of leather, I use a walking foot machine. As for the needles, there is no harm using a round point needle on garment or chap leather. The plus is that the round point wont split the fibers in the lining. Regarding round point vs leather point when sewing patches onto leather vests, I started using round points for this work. The reason is that some leather point configurations split the embroidered threads on the patches, whereas the round points are less likely to do that. The embroidery is done with round point needles, so the stitching to attach them should be also. Nobody sees the round holes in the leather under the patches. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members copernicus1234 Posted March 2 Members Report Posted March 2 I See in the picture thread is not looped on pin on first big wheel is that machine correctly threaded Quote
Members nejcek74 Posted March 3 Members Report Posted March 3 You never loop the thread around the pin. Pin is there only to prevent disks from turning. Quote
