4 hours ago, eddiexero said:
I'm definitely gonna try that trick.  I've never heard of that mixture before. Thank you.
Like I said, mix it the tip of a teaspoon too a bowl of warm water. I bag of oxalic acid will last you years. Home Depot has it, as others. Take a bar of saddle soap and a shampoo bottle. Scrap a little in the bottle and add hot water… that bottle will give you a saddle soap mix to use. A little shot of the bottle, with that little bit of tsp, and warm water in a bowl. Sponge. You should always use a saddle soap water mix on your leather when tooling anyway. Make the driest piece of leather look grade A. Give it a try, I think you’ll like the results.
Hello Eddiexero, I experience a (white) cloud affect when I dye vegetable tan leather with Fiebings’s black dye. No matter how many times I’ve cleaned it the “cloud” always appears. I apply the dye when the leather is dry. When the leather dye dries I buff it off and add a second coat and it goes away!
I too use an air brush and I have experienced those markings, which appear to have been splashed (or possibly a spit take) and a half assed attempt was made to wipe it off. If it came from fingers you would of most likely seen finger prints.
i sometimes use a dye-prep that helps clean and prepare the leather for dye. It evaporates rather fast and the dye must be applied while the leather is wet. To apply the dye prep you 1) rinse a sponge till the water is clear. 2) wring the sponge almost dry. 3) Saturate the sponge well with the dye prep 4) evenly wet the entire surface. 5) apply the dye with the surface still damp from the dye prep
one can also make a dye-prep (YouTube)
the more I look at that pattern, the splash could of been a bounced sprite or clear soft drink, a cough or maybe even a sneeze, and it is all possible because you have no idea where that leather has been or the abuse it received in just day to day handling.
Isopropyl alcohol leaves a faint residue where sugar will leave marks like what is displayed on your piece, been there - done that (Golden Retrievers help with all kinds of messes)
if a soft drink dries on leather it must be flushed with water to get it all off, just wiping it with a paper towel won’t do, thus it will look like what you have
Edited by Doc Reaper
Cleaner read
Doc Reaper
Acetone, for really contaminated  surfaces, or for removing a prior top finish only. Alcohol is much better. Then wet the leather a little bit before dyeing
