esantoro Report post Posted November 6, 2007 Is there a foolproof way to check if some trigger snaps are solid brass? I bought a bunch that were supposed to be solid brass, but I don't think they are. I've scratched the surface of both these and ones that are supposed to be brass plated. They both survive the scratch test, no other colored metal shows beneath the surface. My brass plated snaps even look better than these supposedly solid brass snaps. Ed Quote Share this post Link to post Share on other sites
Romey Report post Posted November 6, 2007 Plating often will often look to have a better shine the solid, a good ecample of this is a pre 1984 solid penny and new copper plated zinc penny. Any solid brass or copper ect will darken and patina, and there are even varying things one can do to make cool patina colors Quote Share this post Link to post Share on other sites
Luke Hatley Report post Posted November 6, 2007 (edited) HEY ED... USE A MAGNET... IF IF IS STEEL THE MAGNET WILL TELL YOU THAT IT IS NOT SOLID BRASS. :beer: Edited November 6, 2007 by Luke Hatley Quote Share this post Link to post Share on other sites
esantoro Report post Posted November 6, 2007 Will a magnet also attract zinc, which I think is also known as white metal? I have solid brass dees, and with a magnet there is a very, very slight attraction. Also with these snaps, there is a very, very, slight attraction. I finally took a bolt cutter and started cutting the snaps in sections, both the purported solid brass, and the brass plated, everything looks like it's solid brass, yellow through the middle. They both are cut with the same resistance. Quote Share this post Link to post Share on other sites
Luke Hatley Report post Posted November 6, 2007 ED THE MAGNET WILL ONLY ATTRACT TO STEEL OR IORN. Quote Share this post Link to post Share on other sites
Romey Report post Posted November 7, 2007 Alther thing is not all brass is the same, there are several variations of Brass. Admiralty brass ,Rivet brass,Naval brass and many more all depending on the alloy mix. Brass is any alloy of copper and zinc and should have zero magnetic effect at all. I dont know about "white metal" but there is a white brass thats really brittle. Quote Share this post Link to post Share on other sites
whinewine Report post Posted November 7, 2007 A magnet will attract nickle, too, if it is a high enough concentration. A magnet will not attract a U.S. nickle, but it will definitely attract a Canadian nickle (unless they've changed the formulation like we've changed the formulation of our U.S. cents from copper to copper plated zinc). Quote Share this post Link to post Share on other sites
Romey Report post Posted November 7, 2007 (edited) Good call Edited November 7, 2007 by Romey Quote Share this post Link to post Share on other sites
oldtimer Report post Posted November 7, 2007 (edited) A hacksaw seems to be an alternative to see what´s below the surface . ( costs one snap, but you´ll know for sure if it is brass or zink) Edited November 7, 2007 by oldtimer Quote Share this post Link to post Share on other sites
