PastorBob Posted September 22, 2022 Report Posted September 22, 2022 A beautiful piece of workmanship for a beautiful rifle. Well done. Did you sew by hand or machine? Quote In God's Grace, Pastor Bob "While we were yet sinners, Christ died for us." - Romans 5:8 www.PastorBobLeather.com YouTube Channel
Members Tequila Posted September 22, 2022 Members Report Posted September 22, 2022 @AndrewWR beautiful looking case, I like the handle detail. Got a question how did you get the edge to lay flat on the curves, when I try to do it the edge material puckers. Quote
Members AndrewWR Posted September 22, 2022 Author Members Report Posted September 22, 2022 2 hours ago, PastorBob said: A beautiful piece of workmanship for a beautiful rifle. Well done. Did you sew by hand or machine? All Hand sewn, @PastorBob. I don't have sewing machine can't justify the cost or space as a hobbyist. If I was running a business, it'd be different but I think I still prefer the netness and quality of hand sewn leather. Which brings me to @Tequila 's question: 1 hour ago, Tequila said: @AndrewWR beautiful looking case, I like the handle detail. Got a question how did you get the edge to lay flat on the curves, when I try to do it the edge material puckers. Tequila, I don't think what I did here can be done with a machine (But I'm willing to be corrected on that). Because it's hand sewn, I punch all the holes first and each stitch pulls them into alignment close to the inner radius. I wet the middle of the edging strip with a cotton bud so the leather is more inclined to stretch around the outer radius. This stretch is only a fraction of a millimeter at a time, since the stitches are 4mm spacing. As I understand it, machine sewing doesn't allow this progressive tension so the outer radius is unstretched and the inner radius puckers under compression. This is time consuming work but I happen to think it's worth it. Quote
Members Tequila Posted September 22, 2022 Members Report Posted September 22, 2022 25 minutes ago, AndrewWR said: All Hand sewn, @PastorBob. I don't have sewing machine can't justify the cost or space as a hobbyist. If I was running a business, it'd be different but I think I still prefer the netness and quality of hand sewn leather. Which brings me to @Tequila 's question: Tequila, I don't think what I did here can be done with a machine (But I'm willing to be corrected on that). Because it's hand sewn, I punch all the holes first and each stitch pulls them into alignment close to the inner radius. I wet the middle of the edging strip with a cotton bud so the leather is more inclined to stretch around the outer radius. This stretch is only a fraction of a millimeter at a time, since the stitches are 4mm spacing. As I understand it, machine sewing doesn't allow this progressive tension so the outer radius is unstretched and the inner radius puckers under compression. This is time consuming work but I happen to think it's worth it. I don’t have as much patience as you, so a tip of the hat to you for that long tedious work, and your right the outcome was worth the effort. Thanks for sharing your knowledge and technique with everyone. Quote
