Members SalInRI Posted October 10, 2022 Members Report Posted October 10, 2022 I've looked high and low and can't find a procedure for splicing single loop edge braid on a single layer of leather. There's lots of stuff about splicing on two layers where you bring the tail up between the layers, but I can't find anything about splicing on a single layer strap. Does anyone have directions for doing this? Quote
Members KnotHead Posted October 10, 2022 Members Report Posted October 10, 2022 (edited) On a single piece of leather you’ll tuck tuck the ends in on the sides. Edited October 10, 2022 by KnotHead Quote
Northmount Posted October 10, 2022 Report Posted October 10, 2022 10 hours ago, SalInRI said: splicing To add an additional length of lace, do a wet splice, skive the ends to be joined, glue them together. Takes a little practice to make it appear to be a continuous piece of lace. Quote
Members SalInRI Posted October 10, 2022 Author Members Report Posted October 10, 2022 @knothead, I see that for beginning and ending, but what about in the middle of the project? @northmount, thank you. I was hoping there was a method to splice without the wet splice. Any thoughts? Quote
Members SalInRI Posted October 10, 2022 Author Members Report Posted October 10, 2022 @northmount, also: How much of the lace do you skive on each side for a proper wet splice? 1/4"? Quote
Northmount Posted October 11, 2022 Report Posted October 11, 2022 5 hours ago, SalInRI said: I was hoping there was a method to splice without the wet splice. If the leather is thick enough, you can split the leather so you have 2 layers and hide the ends inside. Again, you will need lots of practice to make this work. 5 hours ago, SalInRI said: How much of the lace do you skive on each side for a proper wet splice I try to get towards 1" of overlap. I don't think 1/4" provides enough surface to make a good strong splice. Quote
