Mike1690 Report post Posted October 26, 2022 Hi everyone How and can i bevel, debose and emboss on a ready made vegtan leather items? Ie wallets Quote Share this post Link to post Share on other sites
fredk Report post Posted October 26, 2022 You will need to either a. take the item apart or b. get a piece of medium thickness aluminium or steel plate just big enough to slip inside the item and to where you want to stamp or decorate Quote Share this post Link to post Share on other sites
Mike1690 Report post Posted October 26, 2022 Thanks fredk Quote Share this post Link to post Share on other sites
Handstitched Report post Posted October 26, 2022 3 hours ago, fredk said: get a piece of medium thickness aluminium or steel plate just big enough to slip inside the item and to where you want to stamp or decorate 3 hours ago, Mike1690 said: Ie wallets I have put a piece of wood inside the item . Also, as you mentioned wallets, and I assume the leather is thin (?) be careful not to hit the tool too hard as it may go straight through. A piece of scrap leather inside will help with that. HS Quote Share this post Link to post Share on other sites
Bert03241 Report post Posted October 26, 2022 I wouldn't use wood as it might mush when you hit it, splinter and just make a mess. I get some 1/8 or 1/4 flat steel bar what ever width you need from home depot. inch or inch and a half works for mot projects zi have had to do that way. works also when you forget the snap LOL Quote Share this post Link to post Share on other sites
