I have a Durkopp that I was told is a 17-2-2. According to the instructions manual it may well be a 17-5 or 17-6. Regardless of which model it is, i need needles for leather. I have been told a 17-2-2 has 56mm needles, but can find no such needle length. Any help would be appreciated.
@Wozzer Moved your post to Leather Sewing Machines.  Help wanted is like the classifieds in a newspaper, people looking for work, or job posting sort of thing.  All posts to Help Wanted require a moderators' approval before they become visible.  Since you are a member, you can post in any of the other forums without having to have the posts approved.
Lots of sewing machine guys here to give you a hand.
Wozzer ,
I got you.  Check your  messages.
glenn
  • 2 weeks later...
System 88 shank dia.  1.9mm, 332 LG   shank dia.  2.0mm
glenn
21 hours ago, Constabulary said:
332 LONG has a slightly lager shank diameter than the 332 IIRC
lager shank diameter than System 88 I wanted to say...
Thanks for confirming, Glenn.  ;)
