Members Michiel Posted October 31, 2022 Members Report Posted October 31, 2022 College sewing in london and sometimes armastore.eu sometimes i am lucky when i google the parts number did you find a parts manual online? college sewing has them on their website: https://www.college-sewing.co.uk/parts-books/durkopp-adler-parts-books.html Quote
Members Escritar Posted November 12, 2022 Author Members Report Posted November 12, 2022 I have purchased screws that hold the spring on the bobbin cap twice from 2 different vendors and both have been the incorrect screws. The screws I keep receiving are for the 167 bobbin cap which are a larger diameter than the screws for the 67 bobbin cap. The parts numbers below are for the screws I have received thus far: 992 019 148 Tension Spring Fixing Screw (this is a part for the 167 machine) 992 019 157 Tension Spring Adjustment Screw (this is a part for the 167 machine) 992 023 510 Tension Spring Adjustment Screw (this was supposed to be a part for the 67 machine) 992 023 500 Tension Spring Fixing Screw (this was supposed to be a part for the 67 machine) The screws I have received for the part numbers above all appear to be the same size. They are clearly the same size as the screws for the 167 machine. These screws have a larger diameter than the screws for the bobbin cap used in the 67 machine. In your parts book for the Adler 67, what are the part numbers for the Tension Spring Adjustment and Tension Spring Fixing screws? Thank You, Roger Quote
Members shoepatcher Posted November 12, 2022 Members Report Posted November 12, 2022 Durkopp Adler had 2 different screws for the tension spring and 2 different for the attaching screw depending on serial number of the machine. Seems like they made a running change sometime in production. Here are the numbers via the parts list I have. tension screw #992-10-746-8 or #992-02-351-0 attaching screw #992-12-255-8 or#992-02-350-0 Call Durkopp Adler Pfaff in Georgia and order from them. They take credit cards. glenn Quote
Members Escritar Posted November 12, 2022 Author Members Report Posted November 12, 2022 Thank You for the part numbers and information regarding ordering parts directly from Durkopp Addler/Pfaff Quote
