54 minutes ago, AlZilla said:
The pan head screw does not work.  The original one is a slotted flat head because there's not much clearance between the hook and the bobbin case.  It rotated fine until I needed to back it out to decrease bobbin tension, then it binds.
I suppose I could pull it out and  reshape the head. But another hour or so of screwing around isn't worth the effort.
Too bad, I was >this< close to having the tension balanced ...
Just thought I'd jump in here & let you know we have these screws in stock.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
It sounds like he kit-bashed a farm supplies store screw into the bobbin case. If true, the threads may be ruined for the proper tension screw and he might need a complete bobbin case.
Posted IMHO, by Wiz
Not at all.  The thread is #0-80. I just shortened it.  If it were a flathead I'd be in business.  A. new hook and case will be here in a day or two.
- Voltaire
- Aristotle
