CowboyBob Posted December 20, 2022 Report Posted December 20, 2022 (edited) 17 hours ago, sojourner999 said: Thank you. @Jhunter13 walked me through this when I was at the sellers property. It is belt drive. I can see the cutout. I line it up with the disk, but it doesn’t appear to catch. I tried holding a screw driver on the disk and was able to turn the hand wheel, so it appears it is not stuck. I just can’t get the stitch length button to catch the indent. Looking at it, from a weird angle, it appears to not be centered in the cutout. Maybe it could also be the button was ground down from improper use? How would you remove and re-install the stitch length button? And if it is not the button being too short, can you recommend how I would adjust the “left/right” of the disk so the button is in line with it? much appreciated, Looks to me like you need to loosen the 2-screws that hold the stitch length cam to the shaft & only turn them 1/4 turn(because one of them goes into a slot on the shaft) & then tap on it to slide it to the left so it lines up. Edited December 20, 2022 by CowboyBob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members sojourner999 Posted December 20, 2022 Author Members Report Posted December 20, 2022 1 hour ago, CowboyBob said: Looks to me like you need to loosen the 2-screws that hold the stitch length cam to the shaft & only turn them 1/4 turn(because one of them goes into a slot on the shaft) & then tap on it to slide it to the left so it lines up. Thank you. I am going to look into that. I am reading the manuals now. Quote
