stampingdelight
iso knight surcoat pattern/template
Got to Target or Goodwill and buy a cheap bathrobe with the desired shoulder width, cut off the arms and trim the front so it doesn't overlap as much. That should give you a running start, and you can cut it apart at the seams to make into a flat pattern.
or you could look for 'Simplicity' or 'McCalls' sewing pattern packs
Simplicity 9593 Men's Coat, Jacket and Vest sewing pattern — jaycotts.co.uk  - Sewing Supplies
Edited by fredk
