MikeRock Posted January 6, 2023 Report Posted January 6, 2023 Can you just hit the cut out pattern with a bit of 220 grit paper and eliminate that little step? I can't even see it on the clear plastic pieces. Quote
Members Danne Posted January 6, 2023 Author Members Report Posted January 6, 2023 1 hour ago, MikeRock said: Can you just hit the cut out pattern with a bit of 220 grit paper and eliminate that little step? I can't even see it on the clear plastic pieces. Yes, it's no problem with the templates, I will have to sand the inner edges of the larger parts anyway (they will be used to flush cut straps with padding also, so I have to remove the sharp edge) And the exterior patterns are cut to the finished dimension, and I will still sand them so they become a little bit more narrow to make room for edge paint. But I still need to solve this problem, I'm a perfectionist and this doesn't work long term. Quote
MikeRock Posted January 6, 2023 Report Posted January 6, 2023 "But I still need to solve this problem, I'm a perfectionist and this doesn't work long term." Ah yes......my whole engineering career in those few words... God bless Quote
