Members Klara Posted January 19, 2023 Members Report Posted January 19, 2023 Two years ago I wondered why so many knife rolls had the handles in the pocket and the blades exposed, now I think I know: Because the makers had the same question I have now: How does one stop the point from poking through the pocket? I want to make a simple knife roll type thingy for two nail files and a polishing board, in order to replace the plastic pocket they came in (which they poked through). I do not want to make the wonderful but fairly complex manicure case in The Art of Making Leather Cases (vol. 2, I think). I was thinking about simply folding over the leather at the bottom for the pockets, sewing the edges closed and the separations between the files - classic tool roll design. But I am wondering how long such a construction will last. Does anybody have better ideas? Quote
Members Gezzer Posted January 19, 2023 Members Report Posted January 19, 2023 Maybe not a better idea .......... just different . Well if I understand right I would sew it up and then figure a way to add a small amount of epoxy in the very bottom of pocket in an open position and allow to harden . I think this would prevent ( poke through ) and provide a small amount of space for movement . Good luck with whatever you come up with !!!!!!!! Quote
Contributing Member fredk Posted January 19, 2023 Contributing Member Report Posted January 19, 2023 32 minutes ago, Klara said: Two years ago I wondered why so many knife rolls had the handles in the pocket and the blades exposed, now I think I know: Because the makers had the same question I have now: How does one stop the point from poking through the pocket? I must disagree with this idea. A chef's knife is no sharper than a good field knife and they don't 'poke' holes in their sheaths One reason I think for having the blades exposed is that in sets of high quality chefs knives all have the exact same handle. By exposing the blades the chef can pick his/her knife easier. My #1 has a top quality set of knives and they all have the exact same handle and except for maybe two of the set all the blades are a similar length. He keeps the knives in a box in a drawer so he can select one easily. He tried to use a knife block but he found he was pulling out each knife in turn until he found the one he needed Quote Al speling misteaks aer all mi own werk..
CFM chuck123wapati Posted January 19, 2023 CFM Report Posted January 19, 2023 3 hours ago, Klara said: Two years ago I wondered why so many knife rolls had the handles in the pocket and the blades exposed, now I think I know: Because the makers had the same question I have now: How does one stop the point from poking through the pocket? I want to make a simple knife roll type thingy for two nail files and a polishing board, in order to replace the plastic pocket they came in (which they poked through). I do not want to make the wonderful but fairly complex manicure case in The Art of Making Leather Cases (vol. 2, I think). I was thinking about simply folding over the leather at the bottom for the pockets, sewing the edges closed and the separations between the files - classic tool roll design. But I am wondering how long such a construction will last. Does anybody have better ideas? use a welt in it. sew in a small thickness of leather into the bottom about 3/8ths" wide so the tips will hit that instead of the bottom of the roll. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM chuck123wapati Posted January 19, 2023 CFM Report Posted January 19, 2023 i doubt highly that your nail files will punch through leather as easily as the plastic they came with at least the ones over here wouldn't they have a very blunt point unlike a knife. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Klara Posted January 19, 2023 Author Members Report Posted January 19, 2023 2 hours ago, fredk said: a good field knife and they don't 'poke' holes in their sheaths I always thought that knife sheaths were constructed with a welt to avoid poking holes. 2 minutes ago, chuck123wapati said: sew in a small thickness of leather into the bottom about 3/8ths" wide so the tips will hit that instead of the bottom of the roll Oh yes, you are right, I can just sew in a flat piece of leather. I was hung up on the fold and how to do it with thicker leather, and... Thanks! Quote
