CFM chuck123wapati Posted January 30, 2023 CFM Report Posted January 30, 2023 On 1/25/2023 at 2:34 PM, BDAZ said: Brilliant! I'll give it a go... Bob I looked on Amazon, didn't check Ebay. Thanks! Bob they make lacing chisels. https://tandyleather.com/products/pro-line-lacing-chisels-532?_pos=1&_sid=7f29206c3&_ss=r Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members BDAZ Posted January 30, 2023 Author Members Report Posted January 30, 2023 (edited) 31 minutes ago, GrampaJoel said: I just took a cheap screwdriver in the right width to match my lace and ground it until it matched perfectly. Then used it for a punch. I prefer flat punch holes for lace. As apposed to round holes for flat lace. btw, the holster is what the customer wanted. He brought me a photo and I duplicated it. With minor changes so as not to be an actual copy. Joel Thanks, Currently in Chatsworth CA but when I get home I'll test cutting 2mm x 1 mm rectangles at 1mm. I have to punch around 90 running inches so a single blade isn't going to cut it (no pun intended) Bob Edited January 30, 2023 by BDAZ Quote
Members BDAZ Posted January 30, 2023 Author Members Report Posted January 30, 2023 29 minutes ago, chuck123wapati said: they make lacing chisels. https://tandyleather.com/products/pro-line-lacing-chisels-532?_pos=1&_sid=7f29206c3&_ss=r I know, I have a few sets. Thanks, Bob Quote
CFM chuck123wapati Posted January 30, 2023 CFM Report Posted January 30, 2023 On 1/25/2023 at 9:05 AM, BDAZ said: I have to produce a decorative line of lacing on a project which will be around 60 inches and needs to have a tight "wrap" as shown below. All my lacing chisels leave gaps between stitches. Are there any punches for 1/8" lace that could produce these results. I suppose I could hand punch but that would be really time consuming and not in the budget. I have the possibility of either marking punch holes or even cutting them with my laser, which I will use to "trace" the pattern on the leather but again, a lot of extra work when it seems the right punch may do the trick? Thanks! Bob then i cant help you much i can do this stitch with mine.. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Docado Posted January 30, 2023 Members Report Posted January 30, 2023 Deeter Custom Saddlery makes a buckstitch lacing needle that fits in a cobra 3/4 sewing machine. They also have a video on how to get it set up in machine. Others also make similar needle. No affiliation with any of manufacturers. Quote
Members BDAZ Posted January 30, 2023 Author Members Report Posted January 30, 2023 2 hours ago, Docado said: Deeter Custom Saddlery makes a buckstitch lacing needle that fits in a cobra 3/4 sewing machine. They also have a video on how to get it set up in machine. Others also make similar needle. No affiliation with any of manufacturers. Great information. I'll check it out!! Bob Quote
Members BDAZ Posted February 6, 2024 Author Members Report Posted February 6, 2024 Customer gave me some lame excuses why he wants to "wait" on the belt... Never trust any music producers from Nashville. Ask me how I know! Bob (former WEA recording artist) Quote
