Members shoepatcher Posted February 9, 2023 Members Report Posted February 9, 2023 (edited) I think you indeed have the heavier model. It uses the 214x 1 needle which is the same as the 328 system. The fact that the model plates says 8345/34 and not 8345/30 means it is the heavy one and that you can put a 214 x 1 needle in it. The shank on the 214 x1 is larger than on a 88 needle which has a shank of 1.9mm. The 214 x 1 shank is 2.5mm. Damn!!! You have one I have been looking for almost 30 years!! You want the 214x 1 or 2 needle system. I am in Oxford, MI. I see you were in Dearborn, MI. You coming back to the states anytime soon? I have a 8345/30 if you want to trade. We would only have to trade heads!!! Edited February 9, 2023 by shoepatcher Quote
Members Kristian99 Posted February 9, 2023 Author Members Report Posted February 9, 2023 3 hours ago, shoepatcher said: I think you indeed have the heavier model. It uses the 214x 1 needle which is the same as the 328 system. The fact that the model plates says 8345/34 and not 8345/30 means it is the heavy one and that you can put a 214 x 1 needle in it. The shank on the 214 x1 is larger than on a 88 needle which has a shank of 1.9mm. The 214 x 1 shank is 2.5mm. Damn!!! You have one I have been looking for almost 30 years!! You want the 214x 1 or 2 needle system. I am in Oxford, MI. I see you were in Dearborn, MI. You coming back to the states anytime soon? I have a 8345/30 if you want to trade. We would only have to trade heads!!! Makes a lot of sense now. They are pretty difficult to come by even in Europe cant imagine about the US. This particular machine was my fathers so ill be keeping it BUT if I manage to find any other heavy duties in the future I can get in touch. Quote
Members Constabulary Posted February 10, 2023 Members Report Posted February 10, 2023 I do not agree that the 34 subclass is the "heavy subclass" - see above list of sub classes. The 34 is the same as the 30 but with motor stand. The motor stand makes it a 34 everything else is like the 30 incl. needle System 88 - the head only w/o treadle or motor stand is the 30. Check the list. IMO the heavier class has the higher foot lift as well, meaning the machine that takes the 214 needles should have a 15mm foot lift. Thats at least how I understand the subclass list. But I`m maybe wrong. How high is the foot lift on your machine? Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted February 10, 2023 Members Report Posted February 10, 2023 (edited) C, My info tells me it should be a 3A on the plate not a 34. The fact that you can get a 214 x1 needle in the needle bar I think means it it the heavy duty version. Enlarging the needle hole in the needle bar to accommodate a 2.5mm shank cannot be easy. Do we know if the lift is 12mm or 15mm?? That needs to be checked!! glenn Edited February 10, 2023 by shoepatcher grammar Quote
DonInReno Posted February 12, 2023 Report Posted February 12, 2023 On 2/8/2023 at 8:15 AM, Kristian99 said: So totally different from the manufacturer recommended "system 88" and different from "332 LG" and somehow they still work... Just a bit confused understanding what a system is and how they differentiate. There is not a requirement for manufacturers to label a needle size using a particular needle system, so there are often multiple needle systems that are mostly interchangeable. I say mostly, because the original specifications may be slightly different, but a more generic needle is the correct shank size and close enough in length, scarf shape and location, and eye location, to work ok. If you have needles that work well, you won’t gain anything with a different system. Before you had the machine there’s always the chance that the needle bar was replaced or the needle hole was enlarged - it’s pretty commonly done to cut down on the amount of different needles someone would have to keep in stock, or if someone gets “free” needles at work or from a friend - we discuss how to do that here pretty regularly. Quote
Members shoepatcher Posted February 13, 2023 Members Report Posted February 13, 2023 (edited) The original needle hole in the needle bar would accommodate a *8 needle system which is 1.9mm shank size the 332LG is 2.0 shank size. That was hard to get that to fit. The 214 x 1 is 2.50mm shank size. you would have to remove the needle bar and machine it to accommodate the larger needle. Not easy unless you replaced it. Did your dad but the machine new? Also check the lift of the feet please to see if 12mm or 15mm. glenn Edited February 13, 2023 by shoepatcher Quote
Members shoepatcher Posted February 20, 2023 Members Report Posted February 20, 2023 Ok I went thru my literature on the 8345 this weekend. The 8345/30 was the sewing head only. The 8345/34 was the head and a motorized stand. It uses system 88 needles. If the 214x1 needle will fit into the the needle bar, that means the needle hole has been modified. Lift is 12mm. Your were correct Constabulary. It is a model 30 and not the heavy duty version which was the 8345/40. glenn Quote
